I am trying to power on a Motor Driver which will enable a water pump to turn on using a simple application that I created using Blynk. However, the internet connection just stays up for something like 5 seconds, and then it disconnects. It does this continuously, hence the whole system is just not functional. I have tried testing the button during the short period of time that it connects to the internet and it is also not working. The button is the one that I want to use to switch on or off the motor driver.
Here is my code:
#include <ESP8266_Lib.h>
int sensor_raw_data;
int mapped_data;
int pump;
SoftwareSerial esdata(3,4);
#define auth "XXXXXXX"
#define ssid "XXXXXXX"
#define pass "XXXXXXX"
ESP8266 wifi(&esp8266);
// Send AT commands
String sendAT(String cmd, const int tmeout) {
String rsp = "";
esdata.print(cmd);
long int time = millis();
while((time + tmeout) > millis()) {
while(esdata.available()) {
char c = esdata.read();
rsp += c;
Serial.print(rsp);
return rsp;
esdata.begin(9600);
sendAT("AT+RST\r\n", 2000);
sendAT("AT\r\n", 1000);
sendAT("AT+CWMODE=1\r\n", 1000);
sendAT("AT+CWJAP=\""said"\",\""pass"\"\r\n", 2000);
while(!esdata.find("OK")) {
sendAT("AT+CIFSR\r\n", 1000);
sendAT("AT+CIPMUX=0\r\n", 1000);
pinMode(A0, INPUT);
pinMode(8, OUTPUT);
sensor_raw_data = analogRead(A0);
mapped_data=map(sensor_raw_data, 0, 1023, 100, 0);
String sensor_value = String(mapped_data);
Serial.print("Sensor Data: ");
Serial.println(mapped_data);
// Display the soil moisture on a gauge. // This is working properly
Blynk.virtualWrite(V5, prdata);
// Send notification if soil moisture is below 80%
if(mapped_data < 80) {
Blynk.notify("Soil Moisture Is Below 80%. Turn On Water Pump.");
Blynk.notify("Soil Moisture Is Above 80%. Turn Off Water Pump.");
String pmp = String(pump);
updateTS(sensor_value, pmp);
delay(2000);
This is the function for the button. In my app, the button is Virtual pin 8. The Motor Driver is connected to Digital pin 8 on the Arduino. Is there something wrong with the function? Or maybe there is actually another way to let the button switch on or off the pump.
BLYNK_WRITE(V8) {
int pinValue = param.asInt();
if(pinValue == 1) {
digitalWrite(8, HIGH);
// This is the value that will be displayed for the pump status in thingspeak API graph.
pump = 100;
digitalWrite(8, LOW);
pump = 0;
