Hello All
Please help me with my project. I use Arduino UNO + ESP8266 as SoftSerial. I made check status for WiFi connection, reconnect to WiFi and server if nessesary, check status for connection to local server. Now I have a problemm - if I change slider status at app several time - have message “Login Timeout” and programm reconnect to server. Some times a have message “Invalid HW cmd: v»Ђ3”
I try to use delay() between sending info but can not understand - is it problem with arduino\esp, or WiFi or local server?
Thank You
My code:
#include <WiFi.h>
#include <ESP8266_Lib.h>
char auth[] = "xxxxxxxxxxxxxxxxx"; // local server
char ssid[] = "xxxxx";
char pass[] = "xxxxxxxxxxx";
char local_server[] = "xxx.xxx.xxx.xxx";
unsigned int port = 8442;
boolean status_WiFi;
void(* resetFunc) (void) = 0; //declare reset function @ address 0
// LEDS Start
WidgetLED led_status(V9); //register to virtual pin 9
//LEDS End
// Water start
#include <OneWire.h>
OneWire ds(4); // OneWire for water temperature
int water_temperature = 0; // water temp from DS18B20
int water_temperature_target = 80;
int water_temperature_delta = 3;
long lastUpdateTimeWaterTemp = 0; // last time water temp update
const int TEMP_WATER_UPDATE_TIME = 2000; // delta water temp update
// Water End
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
int redpin = 11; // select the pin for the red LED
int greenpin =10; // select the pin for the green LED
int bluepin =9; // select the pin for the blue LED
pinMode(LED_BUILTIN, OUTPUT); //led
pinMode(redpin, OUTPUT);
pinMode(bluepin, OUTPUT);
pinMode(greenpin, OUTPUT);
RGB_status_led (HIGH,LOW,LOW);
delay(50);
Blynk.config(wifi, auth, local_server, port);
CheckBlynkStatus ();
delay(50);
Blynk.virtualWrite(V2, water_temperature_delta);
delay(50);
detectWaterTemperature(); // Check water temp from DS18b20
void CheckBlynkStatus ()
bool isconnected = Blynk.connected();
if(!isconnected)
// Blynk.config(wifi, auth, local_server, port);
Serial.println("Blynk not connected :(");
status_WiFi=Blynk.connectWiFi(ssid, pass);
if (status_WiFi) {
Serial.println("WiFi Connected!");
RGB_status_led (LOW,LOW,HIGH);
bool result = Blynk.connect();
if (result)
Serial.println("Blynk connected!");
RGB_status_led (LOW,HIGH,LOW);
Serial.println("WiFi Disconnected (");
int detectWaterTemperature(){
byte data[2];
ds.reset();
ds.write(0xCC);
ds.write(0x44);
if (millis() - lastUpdateTimeWaterTemp > TEMP_WATER_UPDATE_TIME)
lastUpdateTimeWaterTemp = millis();
ds.reset();
ds.write(0xCC);
ds.write(0xBE);
data[0] = ds.read();
data[1] = ds.read();
// Calculate water temperature
water_temperature = (data[1] << 8) + data[0]; water_temperature = water_temperature >> 4;
Serial.println(water_temperature); // Water temperature
if (water_temperature<(water_temperature_target-water_temperature_delta))
Blynk.setProperty(5, "color", "#04C0F8"); // Blue
Blynk.setProperty(V9, "color", "#04C0F8");
Blynk.setProperty(V9, "label", "Cold");
} else
if (water_temperature>(water_temperature_target+water_temperature_delta))
Blynk.setProperty(5, "color", "#D3435C"); // RED
Blynk.setProperty(V9, "color", "#D3435C");
Blynk.setProperty(V9, "label", "HOT");
} else
Blynk.setProperty(5, "color", "#23C48E"); //GREEN
Blynk.setProperty(V9, "color", "#23C48E");
Blynk.setProperty(V9, "label", "OK");
delay(50);
led_status.on();
delay(50);
Blynk.virtualWrite(5, water_temperature);
delay(50);
BLYNK_CONNECTED() {
Blynk.syncAll();
void RGB_status_led (int r, int g, int b)
analogWrite(redpin, r);
analogWrite(greenpin, g);
analogWrite(bluepin, b);
// Water temperature slider
BLYNK_WRITE(V3)
int value = param.asInt(); // Get value as integer
int temp=value; // water_temperature_target+value;
if ((temp>10) && (temp<93))
water_temperature_target=temp;
Blynk.virtualWrite(V1, water_temperature_target);
