this is a guide explaining how to do one of the basic functions of the Blynk app but ive tried multiple times to get the code to work but my Blynk app always says not online for the arduino im using the right auth code and ive tried reuploading the code multiple times with no prevail
here is the code:`/*************************************************************
http://twitter.com/blynk_app
=> USB HOWTO: http://tiny.cc/BlynkUSB
You can send/receive any data using WidgetTerminal object.
App project setup:
Terminal widget attached to Virtual Pin V1
#define BLYNK_PRINT SwSerial
char auth[] = "ejMZiQ2I9msZwHURHhSX67Eoo3EzwenE";
// Attach virtual serial terminal to Virtual Pin V1
WidgetTerminal terminal(V1);
// You can send commands from Terminal to your hardware. Just use
// the same Virtual Pin as your Terminal Widget
BLYNK_WRITE(V1)
// if you type "Marco" into Terminal Widget - it will respond: "Polo:"
if (String("Marco") == param.asStr()) {
terminal.println("You said: 'Marco'") ;
terminal.println("I said: 'Polo'") ;
// Send it back
terminal.print("You said:");
terminal.write(param.getBuffer(), param.getLength());
terminal.println();
// Ensure everything is sent
terminal.flush();
SwSerial.begin(9600);
Blynk.begin(Serial, auth);
// This will print Blynk Software version to the Terminal Widget when
// your hardware gets connected to Blynk Server
terminal.println(F("Blynk v" BLYNK_VERSION ": Device started"));
terminal.println(F("-------------"));
terminal.println(F("Type 'Marco' and get a reply, or type"));
terminal.println(F("anything else and get it printed back."));
terminal.flush();
