Arduino Uno and ESP8266 won't Ping with Blynk App
Hi there. I am making an automated horse feeder fro my senior design capstone class. Two weeks ago, this code allowed me to connect to the Blynk app and it was working properly. Now, I can’t get it to grab an IP address and ping with the Blynk app. Here is the screenshot of the serial port and my code. Any suggestions?
#define RELAY_ON 0
#define RELAY_OFF 1
/*-----( Declare objects )-----*/
/*-----( Declare Variables )-----*/
#define Relay_1  2  // Arduino Digital I/O pin number
#define Relay_2  3
#define Relay_3  4
#define Relay_4  5
#define Relay_5  6
#define Relay_6  7
#include <ESP8266_Lib.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
char auth[] = "726bf57d1f4747b5b3161cacc3b27257";
char ssid[] = "Verizon-MiFi-MSU";
char pass[] = "723cb993";
SoftwareSerial EspSerial(8, 9); // RX, TX
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
WidgetRTC rtc;
void clockDisplay()
  Serial.print(currentTime);
  Serial.print(" ");
  Serial.print(currentDate);
  Serial.println();
  Blynk.virtualWrite(V1, currentTime);
  Blynk.virtualWrite(V2, currentDate);
  rtc.begin();
  timer.setInterval(10000L, clockDisplay);
  digitalWrite(Relay_1, RELAY_OFF);
  digitalWrite(Relay_2, RELAY_OFF);
  digitalWrite(Relay_3, RELAY_OFF);
  digitalWrite(Relay_4, RELAY_OFF);
  digitalWrite(Relay_5, RELAY_OFF);
  digitalWrite(Relay_6, RELAY_OFF);
  pinMode(Relay_1, OUTPUT);
  pinMode(Relay_2, OUTPUT);
  pinMode(Relay_3, OUTPUT);
  pinMode(Relay_4, OUTPUT);
  pinMode(Relay_5, OUTPUT);
  pinMode(Relay_6, OUTPUT);
  delay(4000); //Check that all relays are inactive at Reset
  digitalWrite(Relay_1, RELAY_ON);// set the Relay ON
  delay(1000);              // wait for a second
  digitalWrite(Relay_2, RELAY_ON);// set the Relay ON
  digitalWrite(Relay_1, RELAY_OFF);// set the Relay OFF
  digitalWrite(Relay_2, RELAY_OFF);// set the Relay OFF
  delay(28800000);              // wait for 8 hrs
  digitalWrite(Relay_3, RELAY_ON);// set the Relay ON
  digitalWrite(Relay_4, RELAY_ON);// set the Relay ON
  digitalWrite(Relay_3, RELAY_OFF);// set the Relay OFF
  digitalWrite(Relay_4, RELAY_OFF);// set the Relay OFF
  delay(28800000);              // wait for 8 hours
  digitalWrite(Relay_5, RELAY_ON);// set the Relay ON
  digitalWrite(Relay_6, RELAY_ON);// set the Relay ON
  delay(4000);              // wait see all relays ON
  digitalWrite(Relay_5, RELAY_OFF);// set the Relay OFF
  digitalWrite(Relay_6, RELAY_OFF);// set the Relay OFF
  delay(43200000);              // wait 12 hours
Assuming you haven’t changed any hardware connections or code, then I would suspect that while you can connect to it, you are not getting Internet access (thus not connecting to Blynk’s Cloud Server) via your Verizon-MiFi-MSU.
@kelly.walls34 what kind of loop() is that, wait for 8 hours, wait for 12 hours !!!
Even wait for a second is not recommended in loops associated with ESP’s.
Study the SimpleTimer library that Blynk provides in the zip file you downloaded.
@Costas blew a fuse :smile:
it’s because of delay(); in your loop. The code get stuck and Blynk.run(); never been executed until all delay(); has been executed.
you must change the code by using SimpleTImer to write the relay instead of using delay();
Wow… I know I was tired yesterday, but how did I miss noticing all of this when responding? :confounded: I must have delays in my own mental loop somewhere :stuck_out_tongue:
A post was split to a new topic: Arduino Mega 2560 and ESP8266
