Arduino offline
My blynk is working fine with the arduino with its example code but I am trying to do this code and blynk says arduino offline. Can anyone help me out here please
SoftwareSerial SwSerial(2, 3); // RX, TX
#define BLYNK_PRINT SwSerial
#include <BlynkSimpleSerial.h>
char auth[] = “7402bb785625475288252e9cdad85b40” ;
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 7, 6, 5,4);
const int stepPin = 38;
const int dirPin = 36;
boolean x = true;
boolean y = true;
boolean z = true;
SwSerial.begin(9600);
Blynk.begin(auth);
pinMode(44,INPUT); //car detect sensor
pinMode(45,INPUT); //first floor sensor
pinMode(46,INPUT); //Second floor sensor
pinMode(47,INPUT); //Third floor sensor
pinMode(stepPin,OUTPUT);
pinMode(dirPin,OUTPUT);
lcd.begin(16,2);
lcd.print(“PROJECT MADE BY”);
lcd.setCursor(0,1);
lcd.print(“DHARAM DHANAK”);
delay(2000);
lcd.clear();
while(1)
lcd.print(“SYSTEM READY”);
while(1)
if(digitalRead(30)==HIGH)
motor1();
if(digitalRead(31)==HIGH)
motor2();
else{
if(digitalRead(32)==HIGH)
motor3();
if (digitalRead(47)==HIGH)
Slot(); //or cardetect();
Code snippet should be formatted. Edit your post.
Wrap the code by adding 3 Backtick: ``` symbols:
Example:
 ``` cpp <--put 3 backticks BEFORE your code starts  (cpp means C++ language)
   //Put your code here
 ``` <--insert 3 backticks AFTER your code
**This makes your code readable and with highlighted syntax, like this:**
//comment goes here
void helloWorld() {
   String message =  "hello" + "world";
You are being disconnected because of the FLOOD ERROR.
http://docs.blynk.cc/#troubleshooting-flood-error
