im using server-0.14.0.jar and and IOS app 1.8.2.
17:34:45.827 INFO - Using data dir ‘C:\Users\Cory\AppData\Local\Temp\blynk’
17:34:46.183 INFO - Initializing mail transport. Username : example@gmail.com. SMTP host : smtp.gmail.com:587
17:34:47.514 INFO - Plain tcp/ip hardware server port 8442.
17:34:47.516 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
17:34:48.253 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
17:34:48.448 INFO - SSL hardware port 8441.
17:34:48.455 WARN - ATTENTION. Server certificate paths cert : ‘C:\Users\Cory\Downloads’, key : ‘C:\Users\Cory\Downloads’ - not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs.
17:34:48.556 WARN - ATTENTION. Server certificate paths cert : ‘C:\Users\Cory\Downloads’, key : ‘C:\Users\Cory\Downloads’ - not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs.
17:34:48.635 INFO - Application server port 8443.
17:34:48.693 INFO - HTTP API port 8080.
17:34:48.701 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
17:34:48.837 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
17:34:49.066 INFO - HTTPS API port 9443.
17:34:49.095 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
17:34:49.182 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
17:34:49.293 INFO - HTTPS admin UI port 7443.
17:34:49.368 INFO - HTTP reset pass port 7444.
17:34:49.370 INFO - Web Sockets port 8082.
17:34:49.370 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
17:34:49.472 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
17:34:49.608 INFO - Web SSL Sockets port 8081.
17:37:54.410 WARN - User not logged. /192.168.1.110:46429. Closing.
17:38:07.096 WARN - User not logged. /192.168.1.110:54065. Closing.
17:38:14.399 WARN - User not logged. /192.168.1.110:42219. Closing.
17:38:36.968 ERROR - User not registered. Username ‘cory1988@gmail.com’, /192.168.1.110:56041
17:38:36.971 ERROR - User not registered. Username ‘cory1988@gmail.com’, /192.168.1.110:56041
17:38:36.972 ERROR - User not registered. Username ‘cory1988@gmail.com’, /192.168.1.110:56041
17:38:36.975 ERROR - User not registered. Username ‘cory1988@gmail.com’, /192.168.1.110:56041
17:38:43.951 ERROR - User not registered. Username ‘cory1988@gmail.com’, /192.168.1.110:45349
17:39:13.836 ERROR - User not registered. Username ‘cory1988@gmail.com’, /192.168.1.110:58700
17:39:18.977 ERROR - User not registered. Username ‘cory1988@gmail.com’, /192.168.1.110:33446
17:39:22.488 ERROR - User not registered. Username ‘cory1988@gmail.com’, /192.168.1.110:40960
17:39:33.552 WARN - User not logged. /192.168.1.110:52809. Closing.
17:39:36.534 WARN - User not logged. /192.168.1.110:40437. Closing.
17:39:51.893 ERROR - User not registered. Username ‘cory1988@gmail.com’, /192.168.1.110:36451
17:39:51.895 ERROR - User not registered. Username ‘cory1988@gmail.com’, /192.168.1.110:36451
17:39:51.896 ERROR - User not registered. Username ‘cory1988@gmail.com’, /192.168.1.110:36451
17:41:08.761 ERROR - User not registered. Username ‘cory1988@gmail.com’, /192.168.1.110:47236
17:42:58.415 INFO - Using data dir ‘\path’
17:42:58.612 INFO - Initializing mail transport. Username : example@gmail.com. SMTP host : smtp.gmail.com:587
17:42:59.330 INFO - Plain tcp/ip hardware server port 8442.
17:42:59.333 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
17:42:59.861 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
17:42:59.976 INFO - SSL hardware port 8441.
17:42:59.985 WARN - ATTENTION. Server certificate paths cert : ‘C:\Users\Cory\Downloads’, key : ‘C:\Users\Cory\Downloads’ - not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs.
17:43:00.150 WARN - ATTENTION. Server certificate paths cert : ‘C:\Users\Cory\Downloads’, key : ‘C:\Users\Cory\Downloads’ - not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs.
17:43:00.226 INFO - Application server port 8443.
17:43:00.265 INFO - HTTP API port 8080.
17:43:00.270 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
17:43:00.368 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
17:43:00.545 INFO - HTTPS API port 9443.
17:43:00.574 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
17:43:00.683 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
17:43:00.756 INFO - HTTPS admin UI port 7443.
17:43:00.857 INFO - HTTP reset pass port 7444.
17:43:00.859 INFO - Web Sockets port 8082.
17:43:00.861 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
17:43:00.960 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
17:43:01.052 INFO - Web SSL Sockets port 8081.
17:43:04.280 ERROR - User not registered. Username ‘cory1988@gmail.com’, /192.168.1.110:58470
17:43:06.853 ERROR - User not registered. Username ‘cory1988@gmail.com’, /192.168.1.110:52862
17:43:13.272 ERROR - User not registered. Username ‘cory1988@gmail.com’, /192.168.1.110:54965
17:43:24.440 WARN - User not logged. /192.168.1.110:40298. Closing.
17:43:27.418 WARN - User not logged. /192.168.1.110:38620. Closing.
17:43:51.539 WARN - User not logged. /192.168.1.110:48951. Closing.
17:44:00.625 ERROR - User not registered. Username ‘cory1988@gmail.com’, /192.168.1.110:50443
17:44:00.645 ERROR - User not registered. Username ‘cory1988@gmail.com’, /192.168.1.110:50443
17:44:00.754 ERROR - User not registered. Username ‘cory1988@gmail.com’, /192.168.1.110:50443
17:44:00.768 ERROR - User not registered. Username ‘cory1988@gmail.com’, /192.168.1.110:50443
17:48:42.270 INFO - Using data dir ‘C:\Users\Cory\AppData\Local\Temp\blynk’
17:48:42.483 INFO - Initializing mail transport. Username : example@gmail.com. SMTP host : smtp.gmail.com:587
17:48:43.222 INFO - Plain tcp/ip hardware server port 8442.
17:48:43.225 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
17:48:43.766 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
17:48:44.003 INFO - SSL hardware port 8441.
17:48:44.010 WARN - ATTENTION. Server certificate paths cert : ‘C:\Users\Cory\Downloads’, key : ‘C:\Users\Cory\Downloads’ - not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs.
17:48:44.167 WARN - ATTENTION. Server certificate paths cert : ‘C:\Users\Cory\Downloads’, key : ‘C:\Users\Cory\Downloads’ - not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs.
17:48:44.312 INFO - Application server port 8443.
17:48:44.358 INFO - HTTP API port 8080.
17:48:44.376 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
17:48:44.463 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
17:48:44.535 INFO - HTTPS API port 9443.
17:48:44.564 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
17:48:44.710 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
17:48:44.826 INFO - HTTPS admin UI port 7443.
17:48:44.900 INFO - HTTP reset pass port 7444.
17:48:44.902 INFO - Web Sockets port 8082.
17:48:44.903 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
17:48:45.001 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
17:48:45.093 INFO - Web SSL Sockets port 8081.
17:48:46.595 ERROR - User not registered. Username ‘cory1988@gmail.com’, /192.168.1.110:47912
17:48:49.592 ERROR - User not registered. Username ‘cory1988@gmail.com’, /192.168.1.110:41112
17:48:51.631 ERROR - User not registered. Username ‘cory1988@gmail.com’, /192.168.1.110:46763
17:49:12.117 ERROR - User not registered. Username ‘cory1988@gmail.com’, /192.168.1.110:42308
17:54:00.564 INFO - Trying register user : cory1988@gmail.com
17:54:00.570 INFO - Registered cory1988@gmail.com.
17:54:00.612 INFO - cory1988@gmail.com app joined.
17:55:28.110 ERROR - Error sending email from application. For user cory1988@gmail.com.
javax.mail.AuthenticationFailedException: 535-5.7.8 Username and Password not accepted. Learn more at
535 5.7.8 https://support.google.com/mail/answer/14257 wb7sm14921547pab.3 - gsmtp
at com.sun.mail.smtp.SMTPTransport$Authenticator.authenticate(SMTPTransport.java:914)
at com.sun.mail.smtp.SMTPTransport.authenticate(SMTPTransport.java:825)
at com.sun.mail.smtp.SMTPTransport.protocolConnect(SMTPTransport.java:730)
at javax.mail.Service.connect(Service.java:388)
at javax.mail.Service.connect(Service.java:246)
at javax.mail.Service.connect(Service.java:195)
at javax.mail.Transport.send0(Transport.java:254)
at javax.mail.Transport.send(Transport.java:124)
at cc.blynk.server.notifications.mail.MailWrapper.send(MailWrapper.java:58)
at cc.blynk.server.notifications.mail.MailWrapper.send(MailWrapper.java:44)
at cc.blynk.server.application.handlers.main.logic.AppMailLogic.lambda$mail$0(AppMailLogic.java:66)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
17:55:35.068 ERROR - Error sending email from application. For user cory1988@gmail.com.
535 5.7.8 https://support.google.com/mail/answer/14257 p75sm14886033pfi.29 - gsmtp
17:55:54.642 ERROR - Error sending email from application. For user cory1988@gmail.com.
535 5.7.8 https://support.google.com/mail/answer/14257 wx3sm14899835pab.25 - gsmtp
17:56:27.416 INFO - Trying register user : cory1988@gmail.com
17:56:27.416 WARN - User with name cory1988@gmail.com already exists.
17:56:27.443 INFO - cory1988@gmail.com app joined.
18:00:04.669 INFO - cory1988@gmail.com app joined.
18:01:27.023 WARN - User not logged. /192.168.1.110:41157. Closing.
18:01:32.275 WARN - User not logged. /192.168.1.110:32783. Closing.
18:01:49.311 WARN - User not logged. /192.168.1.110:57509. Closing.
18:02:58.102 INFO - cory1988@gmail.com app joined.
18:07:17.130 ERROR - Unsecured connection attempt. Channel : /192.168.1.101:39600. Reason : javax.net.ssl.SSLException: Received fatal alert: unknown_ca
18:07:20.346 ERROR - Unsecured connection attempt. Channel : /192.168.1.101:39601. Reason : javax.net.ssl.SSLException: Received fatal alert: unknown_ca
18:07:23.691 ERROR - Unsecured connection attempt. Channel : /192.168.1.101:39602. Reason : javax.net.ssl.SSLException: Received fatal alert: unknown_ca
18:07:26.823 ERROR - Unsecured connection attempt. Channel : /192.168.1.101:39603. Reason : javax.net.ssl.SSLException: Received fatal alert: unknown_ca
18:07:29.946 ERROR - Unsecured connection attempt. Channel : /192.168.1.101:39604. Reason : javax.net.ssl.SSLException: Received fatal alert: unknown_ca
18:07:57.281 ERROR - Unsecured connection attempt. Channel : /192.168.1.101:39606. Reason : javax.net.ssl.SSLException: Received fatal alert: unknown_ca
18:08:00.449 ERROR - Unsecured connection attempt. Channel : /192.168.1.101:39608. Reason : javax.net.ssl.SSLException: Received fatal alert: unknown_ca
18:08:03.561 ERROR - Unsecured connection attempt. Channel : /192.168.1.101:39609. Reason : javax.net.ssl.SSLException: Received fatal alert: unknown_ca
18:08:06.694 ERROR - Unsecured connection attempt. Channel : /192.168.1.101:39610. Reason : javax.net.ssl.SSLException: Received fatal alert: unknown_ca
18:08:10.078 ERROR - Unsecured connection attempt. Channel : /192.168.1.101:39611. Reason : javax.net.ssl.SSLException: Received fatal alert: unknown_ca
18:08:19.637 ERROR - Unsecured connection attempt. Channel : /192.168.1.101:39612. Reason : javax.net.ssl.SSLException: Received fatal alert: unknown_ca
18:08:23.091 ERROR - Unsecured connection attempt. Channel : /192.168.1.101:39613. Reason : javax.net.ssl.SSLException: Received fatal alert: unknown_ca
18:08:25.936 ERROR - Unsecured connection attempt. Channel : /192.168.1.101:39614. Reason : javax.net.ssl.SSLException: Received fatal alert: unknown_ca
18:09:15.847 INFO - Using data dir ‘C:\Users\Cory\AppData\Local\Temp\blynk’
18:09:16.472 INFO - Initializing mail transport. Username : example@gmail.com. SMTP host : smtp.gmail.com:587
18:09:16.968 INFO - Plain tcp/ip hardware server port 8442.
18:09:16.971 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
18:09:17.514 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
18:09:17.776 INFO - SSL hardware port 8441.
18:09:17.783 WARN - ATTENTION. Server certificate paths cert : ‘C:\Users\Cory\Downloads’, key : ‘C:\Users\Cory\Downloads’ - not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs.
18:09:17.995 WARN - ATTENTION. Server certificate paths cert : ‘C:\Users\Cory\Downloads’, key : ‘C:\Users\Cory\Downloads’ - not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs.
18:09:18.157 INFO - Application server port 8443.
18:09:18.195 INFO - HTTP API port 8080.
18:09:18.198 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
18:09:18.268 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
18:09:18.364 INFO - HTTPS API port 9443.
18:09:18.380 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
18:09:18.446 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
18:09:18.517 INFO - HTTPS admin UI port 7443.
18:09:18.697 INFO - HTTP reset pass port 7444.
18:09:18.698 INFO - Web Sockets port 8082.
18:09:18.699 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
18:09:18.758 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
18:09:18.861 INFO - Web SSL Sockets port 8081.
18:09:35.155 ERROR - Unsecured connection attempt. Channel : /192.168.1.101:39619. Reason : javax.net.ssl.SSLException: Received fatal alert: unknown_ca
18:09:38.458 ERROR - Unsecured connection attempt. Channel : /192.168.1.101:39620. Reason : javax.net.ssl.SSLException: Received fatal alert: unknown_ca
18:09:41.585 ERROR - Unsecured connection attempt. Channel : /192.168.1.101:39621. Reason : javax.net.ssl.SSLException: Received fatal alert: unknown_ca
18:11:36.809 INFO - cory1988@gmail.com app joined.
18:15:22.411 ERROR - Unsecured connection attempt. Channel : /192.168.1.101:39636. Reason : javax.net.ssl.SSLException: Received fatal alert: unknown_ca
18:15:25.602 ERROR - Unsecured connection attempt. Channel : /192.168.1.101:39637. Reason : javax.net.ssl.SSLException: Received fatal alert: unknown_ca
18:15:46.035 ERROR - Unsecured connection attempt. Channel : /192.168.1.101:39638. Reason : javax.net.ssl.SSLException: Received fatal alert: unknown_ca
18:15:49.858 ERROR - Unsecured connection attempt. Channel : /192.168.1.101:39640. Reason : javax.net.ssl.SSLException: Received fatal alert: unknown_ca
18:15:52.978 ERROR - Unsecured connection attempt. Channel : /192.168.1.101:39641. Reason : javax.net.ssl.SSLException: Received fatal alert: unknown_ca
18:15:56.117 ERROR - Unsecured connection attempt. Channel : /192.168.1.101:39642. Reason : javax.net.ssl.SSLException: Received fatal alert: unknown_ca
18:17:55.091 ERROR - Unsecured connection attempt. Channel : /192.168.1.101:51596. Reason : javax.net.ssl.SSLException: Received fatal alert: unknown_ca
18:17:58.217 ERROR - Unsecured connection attempt. Channel : /192.168.1.101:51598. Reason : javax.net.ssl.SSLException: Received fatal alert: unknown_ca
18:18:01.381 ERROR - Unsecured connection attempt. Channel : /192.168.1.101:51599. Reason : javax.net.ssl.SSLException: Received fatal alert: unknown_ca
18:18:04.513 ERROR - Unsecured connection attempt. Channel : /192.168.1.101:51600. Reason : javax.net.ssl.SSLException: Received fatal alert: unknown_ca
18:18:10.607 WARN - User not logged. /192.168.1.101:41535. Closing.
18:18:13.743 WARN - User not logged. /192.168.1.101:41536. Closing.
18:18:55.303 ERROR - Not secure connection attempt detected. not an SSL/TLS record: 0200010020366234616237643835373666346365333933366465613530393730. IP /192.168.1.147:24853
18:18:55.321 ERROR - Not secure connection attempt detected. not an SSL/TLS record: 3130623266. IP /192.168.1.147:24866
18:19:00.292 ERROR - Not secure connection attempt detected. not an SSL/TLS record: 0200010020366234616237643835373666346365333933366465613530393730. IP /192.168.1.147:24867
18:19:00.308 ERROR - Not secure connection attempt detected. not an SSL/TLS record: 3130623266. IP /192.168.1.147:24868
18:19:05.284 ERROR - Not secure connection attempt detected. not an SSL/TLS record: 0200010020366234616237643835373666346365333933366465613530393730. IP /192.168.1.147:24869
18:19:05.299 ERROR - Not secure connection attempt detected. not an SSL/TLS record: 3130623266. IP /192.168.1.147:24870
18:19:10.273 ERROR - Not secure connection attempt detected. not an SSL/TLS record: 0200010020366234616237643835373666346365333933366465613530393730. IP /192.168.1.147:24871
18:19:10.289 ERROR - Not secure connection attempt detected. not an SSL/TLS record: 3130623266. IP /192.168.1.147:24872
18:20:17.019 INFO - cory1988@gmail.com app joined.
18:20:46.207 ERROR - Error sending email from application. For user cory1988@gmail.com.
535 5.7.8 https://support.google.com/mail/answer/14257 by3sm14979024pab.39 - gsmtp
18:20:51.440 ERROR - Error sending email from application. For user cory1988@gmail.com.
535 5.7.8 https://support.google.com/mail/answer/14257 fk9sm15016545pad.9 - gsmtp
18:25:49.365 WARN - User not logged. /192.168.1.147:27372. Closing.
18:25:55.893 INFO - cory1988@gmail.com hardware joined.
18:28:25.301 INFO - cory1988@gmail.com app joined.
18:33:57.844 INFO - cory1988@gmail.com hardware joined.
18:39:29.909 INFO - cory1988@gmail.com hardware joined.
18:47:08.810 INFO - cory1988@gmail.com app joined.
18:47:51.136 INFO - cory1988@gmail.com hardware joined.
18:49:22.455 WARN - User not logged. /192.168.1.1:47995. Closing.
18:49:26.141 WARN - User not logged. /192.168.1.1:41722. Closing.
18:49:27.721 WARN - User not logged. /192.168.1.1:52989. Closing.
18:49:29.027 WARN - User not logged. /192.168.1.1:58631. Closing.
18:49:46.433 INFO - cory1988@gmail.com app joined.
18:55:00.109 INFO - cory1988@gmail.com hardware joined.
18:57:57.684 INFO - Using data dir ‘C:\Users\Cory\AppData\Local\Temp\blynk’
18:57:58.582 INFO - Initializing mail transport. Username : example@gmail.com. SMTP host : smtp.gmail.com:587
18:58:00.112 INFO - Plain tcp/ip hardware server port 8442.
18:58:00.116 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
18:58:00.900 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
18:58:01.045 INFO - SSL hardware port 8441.
18:58:01.052 WARN - ATTENTION. Server certificate paths cert : ‘C:\Users\Cory\Downloads’, key : ‘C:\Users\Cory\Downloads’ - not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs.
18:58:01.137 WARN - ATTENTION. Server certificate paths cert : ‘C:\Users\Cory\Downloads’, key : ‘C:\Users\Cory\Downloads’ - not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs.
18:58:01.394 INFO - Application server port 8443.
18:58:01.437 INFO - HTTP API port 8080.
18:58:01.445 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
18:58:01.556 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
18:58:01.691 INFO - HTTPS API port 9443.
18:58:01.842 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
18:58:01.924 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
18:58:02.005 INFO - HTTPS admin UI port 7443.
18:58:02.305 INFO - HTTP reset pass port 7444.
18:58:02.307 INFO - Web Sockets port 8082.
18:58:02.308 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
18:58:02.560 WARN - ATTENTION. Certificate C:\Users\Cory\Downloads and key C:\Users\Cory\Downloads paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
18:58:02.668 INFO - Web SSL Sockets port 8081.
18:58:10.416 INFO - cory1988@gmail.com app joined.
18:58:11.967 INFO - cory1988@gmail.com hardware joined.
18:59:34.791 INFO - cory1988@gmail.com hardware joined.
19:00:05.697 INFO - cory1988@gmail.com app joined.
19:03:19.931 INFO - cory1988@gmail.com hardware joined.
19:04:35.463 INFO - cory1988@gmail.com hardware joined.
19:05:46.617 INFO - cory1988@gmail.com hardware joined.
19:08:38.391 INFO - cory1988@gmail.com hardware joined.
19:10:05.680 INFO - cory1988@gmail.com hardware joined.
19:16:19.918 INFO - cory1988@gmail.com hardware joined.
19:16:37.133 INFO - cory1988@gmail.com app joined.
19:18:32.022 INFO - cory1988@gmail.com hardware joined.
19:27:59.422 INFO - cory1988@gmail.com hardware joined.
19:28:08.242 INFO - cory1988@gmail.com app joined.
19:30:11.593 INFO - cory1988@gmail.com hardware joined.
19:35:36.393 INFO - cory1988@gmail.com hardware joined.
19:36:59.794 INFO - cory1988@gmail.com hardware joined.
19:37:58.179 INFO - cory1988@gmail.com hardware joined.
19:42:51.600 INFO - cory1988@gmail.com hardware joined.
19:43:18.377 INFO - cory1988@gmail.com app joined.
19:43:31.637 INFO - cory1988@gmail.com app joined.
20:30:21.042 INFO - cory1988@gmail.com app joined.
20:34:19.276 INFO - cory1988@gmail.com hardware joined.
20:41:08.434 INFO - cory1988@gmail.com app joined.
20:44:23.988 INFO - cory1988@gmail.com app joined.
20:44:55.569 INFO - cory1988@gmail.com hardware joined.
20:47:42.378 INFO - cory1988@gmail.com app joined.
20:58:00.200 INFO - cory1988@gmail.com app joined.
20:58:39.791 INFO - cory1988@gmail.com app joined.
21:00:10.471 INFO - cory1988@gmail.com app joined.
21:05:26.933 INFO - cory1988@gmail.com hardware joined.
21:06:20.218 INFO - cory1988@gmail.com hardware joined.
21:07:35.478 INFO - cory1988@gmail.com hardware joined.
21:09:25.082 INFO - cory1988@gmail.com hardware joined.
21:09:31.943 INFO - cory1988@gmail.com app joined.
