Hello there! I was 6 months ago working with a soil moisture sensor project of mine and I got it working.
Sadly somehow I lost the files which contained all my custom made projects and forgot how i made it working.
Today somehow I managed it working with this code by using this code by going in Arduino IDE
“Examples->Blynk->Boards USB serial->Arduino serial USB” Pasteing the code under this.
http://twitter.com/blynk_app
=> USB HOWTO: http://tiny.cc/BlynkUSB
Feel free to apply it to any other example. It’s simple!
char auth[] = “your auth token here”;
DebugSerial.begin(9600);
Blynk.begin(Serial, auth);
But my main problem is that I don’t get any option to write down the pin which i need to get data from.
Tried to figure out and search that can I combine multiple sketches before verifying/uploading the sketch into arduino?? Because later I would want to use usb water pump which is communicating with soil moisture.
Or where i can get the sketch which allows me to get data stored in cloud in certain pins and show it in the app in certain values (atm getting reversed soil moisture value where “dry” means value 1023 and wet is 0. and data is stored in Blynk app as long as I’m using the app)
ALso sorry about my poor english, It isn’t my native language and I don’t quite have idea what am I doing anyway :´D
