Arduino Nano + ESP8266 problem
I have the problem withj my project, tested on Mega was OK, but on Nano it’s switching relay ON/OFF/ON/OFF… constantly and doesn’t connect to WiFi.
When I upload simple sketch only with Blynk Connection it’s OK, but on mine sketch there is problem :frowning2: Please help
cpp
#include <Blynk.h>
#include <ESP8266_Lib.h>
//#include <ESP8266WiFi.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
#include <Wire.h>
#include <OneWire.h>
#define ONE_WIRE_BUS 4
char auth[] = "87d571de817c44588e37aa8b27140f6d";
int czujnik_gleby=A0;
int wilg_gleby;
int wilg_gleby_skala = 0;
int wilg_gleby_zadane = 0;
int wyjscie = 2;
int stan_systemu = 0;
char ssid[] = "UKOSNA";
char pass[] = "ukosna123";
#define EspSerial Serial
//#include <SoftwareSerial.h>
//SoftwareSerial EspSerial(8, 9); // RX, TX
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
WidgetRTC rtc;
void podlewanie()
  if ((stan_systemu == 1) && (wilg_gleby_zadane > wilg_gleby_skala))
    digitalWrite(wyjscie,HIGH);
      digitalWrite(wyjscie,LOW);
void clockDisplay()
  Serial.print(currentTime);
  Serial.print(" ");
  Serial.print(currentDate);
  Serial.println();
  sensors.requestTemperatures(); // Polls the sensors
  float temperatura = sensors.getTempCByIndex(0); // Gets first probe on wire in lieu of by address
  Blynk.virtualWrite(V8, temperatura);
  Blynk.virtualWrite(V1, currentTime);
  Blynk.virtualWrite(V2, currentDate);
  Blynk.virtualWrite(V4, digitalRead(22)*15);
BLYNK_WRITE(V7)
  int timer = param.asInt();
  if (timer == 1)
      podlewanie();
BLYNK_WRITE(V6)
  int manual = param.asInt();
  if (manual == 1)
      digitalWrite(wyjscie, HIGH);
BLYNK_WRITE(V5)
  stan_systemu = param.asInt();
  if (stan_systemu == 0)
   digitalWrite(wyjscie, LOW);
BLYNK_WRITE(V9)
  wilg_gleby_zadane = param.asInt();
  pinMode(wyjscie, OUTPUT);
  rtc.begin();
  sensors.begin();
  timer.setInterval(1000L, clockDisplay);
  wilg_gleby=analogRead(czujnik_gleby);
  wilg_gleby_skala=(1024-wilg_gleby)/10;
3, wilg_gleby_skala);
  //delay(1000);
We are not a code factory here, nor are we code mechanics.
The Nano and Mega are significantly different. Have you noted those differences when referencing your hardware pins and how you interface the ESP?
You should also move all of this into it’s own timer loop.
It’s not a real solution. but I would highly recommend using English veriable names. This makes troubleshooting for us a little easier. Judging by your post you are sufficiently skilled in English :slight_smile:
Please, adjust the Baudrate… 115200 is far from being the proper one.
Start with 9600 in both devices (Esp and the Nano)
use hardware serial rather than software serial. software serial seems to cause problems for me
On hardware serialthe same :frowning:
The same, but I wrote earlier that when I use only connection to Blynk and blank program everything is OK
please use a external usb ttl converter and check the serial messages. this would help to debug the problem
There are no messages on serial. Now I transfer this project to NodeMCU and there is same problem
Your new setup is completely different…
NodeMCU has nothing to do with the Nano and Esp as Shield.
Configuration changed, only problem the same
Can you show your code?
#include <Blynk.h>
#include <Wire.h>
char auth[] = "b69c971e9f8f4ddfa0cac745b34e4fff";
int wilg_gleby;
int wyjscie = 2;
WidgetRTC rtc;
void podlewanie()
void clockDisplay()
  Blynk.virtualWrite(V4, digitalRead(2)*15);
  Blynk.virtualWrite(V3, wilg_gleby_skala);
BLYNK_WRITE(V7)
  if (timer == 1)
      podlewanie();
BLYNK_WRITE(V6)
  if (manual == 1)
BLYNK_WRITE(V5)
BLYNK_WRITE(V9)
  rtc.begin();
  sensors.begin();
Where do you connect your sensor?
Gpio4 = D2 on the NodeMCU
psoro - you are right - my mistake, I’ve connected this to D4.
Thanks for help
