Arduino Mkr1000 using sound detector, but not able to connect Blynk so I can receive that it has received sound
Basically the scenario is that a sensor would be placed in a place and if the voice over there goes above the frequency written it will alert the phone with a notification.section 1A is too lout”.
I have also setup the sound detector with the arduino and it is showing in the serial plotter that it can hear my voice. But I don’t know what to do next.
  1. Add details :
    • Blynk Library version
    • Add your sketch code. :point_up:Code should be formatted as example below.
```cpp
