Hi guys, i’m still here to complete my big tranfer on blynk.cloud platform
Have a problem with my MKR1000, sketch looks correct, but after some hours (I do not know exactly) led orange on board blink and i lost signal, below my sketch:
#define BLYNK_TEMPLATE_ID "xxxxxxxxxxxxxxx"
#define BLYNK_DEVICE_NAME "xxxxxxx"
#define BLYNK_AUTH_TOKEN "xxxxxxxxxxxxxxxxxxxxxxxx"
#define BLYNK_PRINT SerialUSB
#include <WiFi101.h>
#include <BlynkSimpleWiFiShield101.h>
#include <TimeLib.h>
char ssid[] = "xxxxxxxxxx";
char pass[] = "xxxxxxxxxxxx";
int ledPin = 14; // LED
int pirPin = 4; // PIR Movimento
int pirStat = 0; // PIR status
int statePir = LOW;
int pinSensore = 6; //PIN A1 luminosità
int pinRele1 = 0; //Relè accensione luce
int pinRele2 = 1; //Relè accensione apertura box
int pinRele3 = 2; //Relè accensione apertura cancello garage
int pinRele4 = 3; //Relè disponibile
int sensorLight, var, varLight, pirSensor, varBox;
float duration, distance;
bool movimento = false;
const int sensorValue = 350;
#define TRIGPIN 8
#define ECHOPIN 7
unsigned long startMillis, currentMillis;
SerialUSB.begin(9600);
Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
startMillis = millis();
pinMode(ledPin, OUTPUT);
pinMode(pinRele1, OUTPUT);
pinMode(pinRele2, OUTPUT);
pinMode(pinRele3, OUTPUT);
pinMode(pinRele4, OUTPUT);
digitalWrite(pinRele1, HIGH);
digitalWrite(pinRele2, HIGH);
digitalWrite(pinRele3, HIGH);
digitalWrite(pinRele4, HIGH);
digitalWrite(ledPin, HIGH);
pinMode(pirPin, INPUT);
pinMode(pinSensore, INPUT);
timer.setInterval(1000L, controlli);
//timer.setInterval(1000L, checkLight);
//timer.setInterval(1000L, distanza);
void distanza() {
digitalWrite(TRIGPIN, LOW);
delayMicroseconds(2);
digitalWrite(TRIGPIN, HIGH);
delayMicroseconds(20);
duration = pulseIn(ECHOPIN, HIGH);
distance = (duration / 2) * 0.0343;
Serial.print("DISTANZA: ");
Serial.println(distance);
//if (digitalRead(pirPin) == HIGH )
//Serial.println("MOVIMENTO RILEVATO ");
void controlli() {
// *****************AREA SENSORI*******************
sensorLight = digitalRead(pinSensore); // verifica lo stato della luce
Serial.print("Sensore: ");
if (sensorLight == 1)
Serial.println("LUCE SPENTA");
Serial.println("LUCE ACCESA");
distanza();
if (distance < 15 && distance >= 7) {
//Serial.println("BOX IN APERTURA");
varBox = 0;
if (distance < 7) {
varBox = 1;
Serial.println("BOX APERTO");
if (sensorLight == 1) {
digitalWrite(ledPin, LOW);
luce();
void checkLight() { //***********RILEVAZIONE MOVIMENTO LUCE ACCESA A BOX****************
if (sensorLight == 0 && distance > 15 && varLight == 0) { //rilevamento luce accesa e box chiuso
if (movimento == false) {
currentMillis = millis();
if (digitalRead(pirPin) == HIGH ) {
currentMillis = millis(); //aggiorna tempo corrente
Serial.print("Tempo rimanente: ");
Serial.println(10000 - (currentMillis - startMillis));
if ((currentMillis - startMillis) > 10000)
luce();
movimento = false;
varBox = 0;
movimento = true;
else movimento = false;
void checkBox() {
if (distance < 7) {
Serial.print("Checkbox");
if (digitalRead(pirPin) == HIGH ) { //se viene rilevato un movimento
Serial.print("Movimento rilevato");
startMillis = millis(); // allinea il tempo corrente al tempo start
if ((currentMillis - startMillis) > 30000) //test whether the period has elapsed
luce();
box129();
movimento = false;
movimento = true;
// VOID PER ILLUMINAZIONE
void luce() {
digitalWrite(pinRele1, LOW);
timer.setTimeout(500L, []() {
void lightOn() { // accensione luce quando il box si apre
if (distance < 50 && sensorLight == 1) {
// ***************VOID PER CANCELLI ******************
void box129() {
digitalWrite(pinRele2, LOW);
timer.setTimeout(1500L, []() {
Serial.println("BOX IN MOVIMENTO");
void garage() {
Serial.println("CANCELLO IN MOVIMENTO");
digitalWrite(pinRele3, LOW);
timer.setTimeout(3000L, []() {
Serial.println("COMANDO APERTURA GARAGE");
//************ CONTROLLO BOX ************************
void openBox() {
if (distance > 15)
box129();
else Serial.println("OSTACOLO PRESENTE!");
void garBox() {
garage();
Serial.print("Tempo: ");
Serial.println(currentMillis);
if ((currentMillis - startMillis) >= 5000) {
openBox();
startMillis = currentMillis;
//*********** PULSANTI *****************************************
BLYNK_WRITE(V0) { // CANCELLO
var = param.asInt();
if (var == 0) garBox();
BLYNK_WRITE(V1) { //BOX
if (var == 1) openBox();
BLYNK_WRITE(V2) { // LUCE FISSA
if (var == 1) {
Serial.println("LUCE FISSA ATTIVA");
varLight = 1;
if (sensorLight == 1) luce();
else {
varLight = 0;
Serial.println("LUCE FISSA DISATTIVA");
luce();
BLYNK_WRITE(V4) { //BOX
if (var == 0) digitalWrite(ledPin, LOW);
else digitalWrite(ledPin, HIGH);
