I am trying to get Blynk running on an Arduino MKR WIFI 1010. I used the example code from the Blynk website. The code uploads fine but when it runs the Arduino will disconnect from the computer as if I am unplugging and plugging the device back in. This happens every 10 seconds or so. If I comment out the Blynk.begin in the setup loop then the problem goes away. I also tried keeping the Blynk.begin in but added in a Serial.println(“hello”) and delay(2000) in front of it to see if that command is hanging it up but I still get the same problem.
Would appreciate any help in getting this solved.
• iOS app
• Blynk server
• Blynk Library version (1.0.1)
You’ll need:
- Blynk IoT app (download from App Store or Google Play)
- Arduino MKR1000 board
example.
#define BLYNK_TEMPLATE_ID "TMP##########"
#define BLYNK_DEVICE_NAME "Quickstart Device"
#define BLYNK_AUTH_TOKEN "###############################"
#define BLYNK_PRINT SerialUSB
#include <WiFi101.h>
#include <BlynkSimpleWiFiShield101.h>
char ssid[] = "#########";
char pass[] = "#########";
SerialUSB.begin(115200);
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
// to avoid delay() function!
