I have following setup for my curing chamber project:
- Board - Arduino Mega
- WiFi - ESP01 - with AT commands - reflashed based on following tutorial - Connecting ESP8266-01 to Arduino UNO/MEGA and BLYNK - Arduino Project Hub
- Android with Blynk - connected to Blynk server
- Blynk version - 1.0.1.
- I have external power supply - because of consumption of ESP01
I have issue with wifi connection. Everything is working fine, Arduino has connect to Blynk server and I can see all data in app.
But after some time the wifi connection is lost and is not reconnected automatically. Actually last run was for 8 hours till connection has been lost.
When the connection is down rest of application is still working.
A read many articles and forum posts to solve this issue, but nothing is working. I already tried following:
- remove all code from loop void
- upgrade Blynk and libraries version to last one
- use soldered joints instead of connectors
- change ESP01 module
I also tried to force lost wifi connection byl covering ESP01 by my hand and when it has been lost I remove my hand and it successfully reconnect to wifi.
Next what I tried was to check if arduino is connected to Blynk server and in other case to restart ESP by ESP.restart() and also call again Blynk.connect().
Nothing helps me.
Please give me sime next tip if you see something what I have wrong in my code.
Thank you
Ladis
Code:
#include <ESP8266_Lib.h>
#include "DHT.h"
char auth[] = "***";
char ssid[] = "***";
char pass[] = "***";
// PINOUT
int dhtPin[] = {3,4}; // IN, OUT
int pinCooling = 8;
int pinHeating = 9;
int pinDrying = 10;
int pinHumidification = 11;
int pinFreshAir = 12;
// VARIABLES
float dhtH[2], dhtT[2];
float dhtHBuffer[2], dhtTBuffer[2];
boolean wifiConnected = false;
int bufferIndex = 0;
float temp = 0;
float hum = 0;
unsigned long waitFromTime = 0;
unsigned long lastFreshAirTime = 0;
unsigned long wifiLostTime = 0;
unsigned long wifiTimeout = 30000;
int wifiReconnecting = 0;
// Input variables
int tempMin = 0; // V100
int tempMax = 100; // V101
double tempDiff = 0; // V102
int humMin = 0; // V103
int humMax = 100; // V104
int humDiff = 0; // V105
int freshAirDuration = 0; // V106
int freshAirTimeout = 0; // V107
int bufferCount = 10; // V110
unsigned long waitAfterAction = 0; // V111
// Output variables
int cooling = 0;
int heating = 0;
int drying = 0;
int humidification = 0;
int waiting = 0;
int freshAir = 0;
WidgetLED coolingLed(V10);
WidgetLED heatingLed(V11);
WidgetLED dryingLed(V12);
WidgetLED humidificationLed(V13);
WidgetLED waitingLed(V14);
WidgetLED freshAirLed(V15);
WidgetTerminal terminal(V125);
DHT dht0(dhtPin[0], DHT21);
DHT dht1(dhtPin[1], DHT21);
ESP8266 wifi(&Serial2);
unsigned long startMillis;
unsigned long currentMillis;
boolean sendValues = false;
void sendToBlynk()
// Start sending data after buffer is filled
if (sendValues) {
if (!isnan(dhtT[0]) && dhtT[0] != 0) Blynk.virtualWrite(V0, dhtT[0]); // TEMP IN
if (!isnan(dhtT[1]) && dhtT[1] != 0) Blynk.virtualWrite(V1, dhtT[1]); // TEMP OUT
if (!isnan(dhtH[0]) && dhtH[0] != 0) Blynk.virtualWrite(V5, dhtH[0]); // HUM IN
if (!isnan(dhtH[1]) && dhtH[1] != 0) Blynk.virtualWrite(V6, dhtH[1]); // HUM OUT
if(cooling) coolingLed.on();
else coolingLed.off();
if(heating) heatingLed.on();
else heatingLed.off();
if(drying) dryingLed.on();
else dryingLed.off();
if(humidification) humidificationLed.on();
else humidificationLed.off();
if(waiting) waitingLed.on();
else waitingLed.off();
if(freshAir) freshAirLed.on();
else freshAirLed.off();
sendValues = false;
void readSensors()
// Read DHT
dhtHBuffer[0] = dhtHBuffer[0] + dht0.readHumidity();
dhtTBuffer[0] = dhtTBuffer[0] + dht0.readTemperature();
dhtHBuffer[1] = dhtHBuffer[1] + dht1.readHumidity();
dhtTBuffer[1] = dhtTBuffer[1] + dht1.readTemperature();
// count buffer
bufferIndex++;
if (bufferIndex >= bufferCount) {
bufferIndex = 0;
dhtH[0] = dhtHBuffer[0] / bufferCount;
dhtT[0] = dhtTBuffer[0] / bufferCount;
dhtH[1] = dhtHBuffer[1] / bufferCount;
dhtT[1] = dhtTBuffer[1] / bufferCount;
dhtHBuffer[0] = 0;
dhtTBuffer[0] = 0;
dhtHBuffer[1] = 0;
dhtTBuffer[1] = 0;
temp = dhtT[0];
hum = dhtH[0];
Serial.print("DHT0 Temperature value is: ");
Serial.println(dhtT[0]);
Serial.print("DHT0 Humidity value is: ");
Serial.println(dhtH[0]);
Serial.print("DHT1 Temperature value is: ");
Serial.println(dhtT[1]);
Serial.print("DHT1 Humidity value is: ");
Serial.println(dhtH[1]);
terminal.print("DHT0 Temperature value is: ");
terminal.println(dhtT[0]);
terminal.print("DHT0 Humidity value is: ");
terminal.println(dhtH[0]);
terminal.print("DHT1 Temperature value is: ");
terminal.println(dhtT[1]);
terminal.print("DHT1 Humidity value is: ");
terminal.println(dhtH[1]);
sendValues = true;
void doAction(){
// Reset waiting
if ( (millis() - waitFromTime) > waitAfterAction * 1000 ) waiting = 0;
// Cooling
if (waiting == 0 && temp > tempMax) {
cooling = 1;
waitFromTime = millis();
if (cooling == 1 && temp <= (tempMax - tempDiff)) {
cooling = 0;
waiting = 1;
// Heating
if (waiting == 0 && temp < tempMin) {
heating = 1;
if (heating == 1 && temp >= tempMin + tempDiff) {
heating = 0;
waiting = 1;
// Drying
if (waiting == 0 && hum > humMax) {
drying = 1;
if (drying == 1 && hum <= (humMax - humDiff)) {
drying = 0;
waiting = 1;
// Humidification
if (waiting == 0 && hum < humMin) {
humidification = 1;
if (humidification == 1 && hum >= (humMin + humDiff)) {
humidification = 0;
waiting = 1;
// Fresh air
if (freshAir == 0 && millis() >= (lastFreshAirTime + ((unsigned long)freshAirTimeout * 1000 * 60) ) ) {
freshAir = 1;
lastFreshAirTime = millis();
if (freshAir == 1 && millis() >= (lastFreshAirTime + ((unsigned long)freshAirDuration * 1000) ) ) {
freshAir = 0;
// set relays
if (cooling == 1) digitalWrite(pinCooling, LOW);
else digitalWrite(pinCooling, HIGH);
if (heating == 1) digitalWrite(pinHeating, LOW);
else digitalWrite(pinHeating, HIGH);
if (drying == 1) digitalWrite(pinDrying, LOW);
else digitalWrite(pinDrying, HIGH);
if (humidification == 1) digitalWrite(pinHumidification, LOW);
else digitalWrite(pinHumidification, HIGH);
digitalWrite(pinFreshAir, LOW);
if (freshAir == 1) digitalWrite(pinFreshAir, LOW);
else digitalWrite(pinFreshAir, HIGH);
Serial.print("cooling value is: ");
Serial.println(cooling);
Serial.print("heating value is: ");
Serial.println(heating);
Serial.print("drying value is: ");
Serial.println(drying);
Serial.print("humidification value is: ");
Serial.println(humidification);
Serial.print("waiting value is: ");
Serial.println(waiting);
Serial.print("freshAir value is: ");
Serial.println(freshAir);
terminal.print("cooling value is: ");
terminal.println(cooling);
terminal.print("heating value is: ");
terminal.println(heating);
terminal.print("drying value is: ");
terminal.println(drying);
terminal.print("humidification value is: ");
terminal.println(humidification);
terminal.print("waiting value is: ");
terminal.println(waiting);
terminal.print("freshAir value is: ");
terminal.println(freshAir);
void syncVariables(){
// System info - Wifi status
if (!wifiConnected && Blynk.connected()) {
wifiConnected = true;
Serial.println("Sync Virtual pins from server");
terminal.println("Sync Virtual pins from server");
// Temp
Blynk.syncVirtual(V100,V101,V102);
// Humidity
Blynk.syncVirtual(V103, V104, V105);
// Fresh air
Blynk.syncVirtual(V106, V107);
// System
Blynk.syncVirtual(V110, V111);
if (wifiConnected && !Blynk.connected()) {
BLYNK_WRITE(V100)
tempMin = param.asInt();
Serial.print("tempMin value is: ");
Serial.println(tempMin);
BLYNK_WRITE(V101)
tempMax = param.asInt();
Serial.print("tempMax value is: ");
Serial.println(tempMax);
BLYNK_WRITE(V102)
tempDiff = param.asDouble();
Serial.print("tempDiff value is: ");
Serial.println(tempDiff);
BLYNK_WRITE(V103)
humMin = param.asInt();
Serial.print("humMin value is: ");
Serial.println(humMin);
BLYNK_WRITE(V104)
humMax = param.asInt();
Serial.print("humMax value is: ");
Serial.println(humMax);
BLYNK_WRITE(V105)
humDiff = param.asInt();
Serial.print("humDiff value is: ");
Serial.println(humDiff);
BLYNK_WRITE(V106)
freshAirDuration = param.asInt();
Serial.print("freshAirDuration value is: ");
Serial.println(freshAirDuration);
BLYNK_WRITE(V107)
freshAirTimeout = param.asInt();
Serial.print("freshAirTimeout value is: ");
Serial.println(freshAirTimeout);
BLYNK_WRITE(V110)
bufferCount = param.asInt();
Serial.print("bufferCount value is: ");
Serial.println(bufferCount);
BLYNK_WRITE(V111)
waitAfterAction = param.asInt();
Serial.print("waitAfterAction value is: ");
Serial.println(waitAfterAction);
// Set ESP8266 baud rate
Serial2.begin(115200);
// DHT
dht0.begin();
dht1.begin();
// Relay
pinMode(pinCooling, OUTPUT);
pinMode(pinHeating, OUTPUT);
pinMode(pinDrying, OUTPUT);
pinMode(pinHumidification, OUTPUT);
pinMode(pinFreshAir, OUTPUT);
terminal.clear();
terminal.println(F("Blynk v" BLYNK_VERSION ": Device started"));
terminal.flush();
timer.setInterval(5000L, sendToBlynk);
timer.setInterval(1000L, readSensors);
timer.setInterval(5000L, doAction);
timer.setInterval(10000L, syncVariables);
