ARDUINO MEGA + ETH - Custom Timer with more than 33 seconds never stops
Hi all
I’m having some troubles with my project. I’ve a greenhouse with some motors that can be remotely opened / closed or put in auto mode for rain detection and auto opening/closing.
On my board I’ve some custom times that archived in an array
BLYNK_WRITE(V34)
   windows_time[0] = param.asInt(); // example
Then in my function :
 time1 = windows_time1[(slide1-1)];
  time2 = windows_time2[(slide2-1)];
 if ( opening_requested==1 && motor1_moving==0 && motor2_moving==0 && windows_open==0){            //IF OPENING REQUESTED AND MOTORS NOT MOVING
  Serial.println("Opening...");
  finecorsa1=digitalRead(finecorsa1C);
  finecorsa2=digitalRead(finecorsa2C);
  opening_start=millis();
  digitalWrite(arcata1C, HIGH);
  digitalWrite(arcata2C, HIGH);
  digitalWrite(arcata1A, LOW);
  digitalWrite(arcata2A, LOW);
  motor1_moving=1;                                 // 1 -  > motor is opening
  motor2_moving=1;
  opening_request==0;
  if( motor1_moving==1 && millis()-opening_start >= (time1*1000)){
            digitalWrite(arcata1A, HIGH);
            motor1_moving=0;
            Serial.println("--- Motor1 STOP");
  if( motor2_moving==1 && millis()-opening_start >= (tempo2*1000)){
            digitalWrite(arcata2A, HIGH);
            motor2_moving=0;
            Serial.println("--- Motor2 Stop");
With that code, if I choose a time greater than 32 seconds, it never stops and I really don’t understand why. It works perfectly with shorter time.
Any suggestion?
Presumably because your windows_time variable is a 16-bit signed integer, with a maximum value range of -32768 to 32767 so 32000ms is the largest value it can store.
If you swap to a long integer it should solve the problem.
