Arduino ESP8266 Direct Connect Sketch
This sketch looks complete, but has a note that TCP connections are not supported by the app. Does this mean that if we have some other way (like the java app client) to direct-connect, this sketch will work?
How was this sketch tested? Is there a way to set the app to TCP? Security is less of an issue for a local AP that is in a protected environment.
I was testing by setting up a bridge using socat utility.
So basically it was NOT a direct connection, rather a simulation.
Keep tuned, we’re already working on it on the App side!
Thanks! Looking forward to it!
