Board: Arduino Mega 2560
Connection : ESP8266 WIFI Shield
Blynk: for Android
I made a simple code for light up and turn off the LED by using real button, I also have button in the Blynk app for switching the same diode.
My problem is that arduino does not react on “real” button until connecting to wifi is already done, it takes about 10 seconds. I mean this:
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.5.4 on Arduino Mega
[599] Connecting to lol
[3648] AT version:1.1.0.0(May 11 2016 18:09:56)
SDK version:1.5.4(baaeaebb)
Ai-Thinker Technology Co. Ltd.
Jun 13 2016 11:29:20
OK
[4733] Failed to enable MUX
[9778] +CIFSR:STAIP,"192.168.43.75"
+CIFSR:STAMAC,"84:f3:eb:b1:29:f8"
[9786] Connected to WiFi
[20222] Ready (ping: 12ms).
Second problem is, when I power up or reset arduino and hotspot is currently not available. Of course I get report :
[13758] Failed to connect WiFi
but after unsuccessfull conection I still can’t work offline by using real push button. Procces is somewhere stopped and waiting for a wifi connection.
My code:
#include <ESP8266_Lib.h>
char auth[] = "***";
char ssid[] = "***";
char pass[] = "***";
#define EspSerial Serial1
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
void myTimerEvent()
int button;
int led;
pinMode(50, INPUT);
pinMode(22, OUTPUT);
digitalWrite (22, LOW);
// Set ESP8266 baud rate
button = digitalRead(50);
led = digitalRead(22);
//Serial.print(button);
if (button == LOW) {
if (led == LOW ) {
led = HIGH;
else {
led = LOW;
digitalWrite(22, led);
while (digitalRead(50) == LOW) {
delay (50);
So i want switching diod with real push button and Blynk button (it works). And using real button, when wifi is not connected ( doesn’t work). And if it is possible using real button when arduino with esp-01 is just connecting to wifi hotspot ( doesn’t work).
The solution will probably be very simple, but i am beginner in arduino programming and programming at all
Thanks for your ideas…
