Add details :
• Blynk Library version
• Add your sketch code. Code should be formatted as example below.
My Bad. I was going to post a problem then realized it was really an Arduino compile issue then instead of cancelling this empty post I hit post.
while I am here I do have a question. I am using a Cytron ESP8266 with Wroom. I get the following message when the Arduino starts: Failed to enable MUX. It does not seem to affect anything as it runs normally. Just wondered what it means and what is hidden behind it.
[846] Connecting to Madrid
[4031] AT version:0.52.0.0(Jan 7 2016 18:44:24)
SDK version:1.5.1(e67da894)
compile time:Jan 7 2016 19:03:11
OK
[5109] Failed to enable MUX
[10305] +CIFSR:STAIP,“192.168.86.94”
