can arducam uno board connect to BLYNK
Do you simply want to use the board to run Blynk code, or do you want the images from the camera to be viewable via the video stream widget in the Blynk app?
i want to be able to stream it on blynk
app
Then you’ll need to find a way to encode the video in a format that’s acceptable to Blynk, and publish the video stream to a URL (one that’s publicly accessible if you want to use the app outside of your home network) then point the video streaming widget to this URL.
If you get it working then come back and share your solution.
