Would you give me a last help? I need to add a flowmeter and let it write the liters / minutes on the virtual pin 4. i do not know where to start. These are the characteristics of the flow meter
1, appearance of product identification clear, accurate to meet the requirements in line
2, hydrostatic pressure less than1.75MPa
3, Operating voltage range DC3 ~ 24V compliance
4, Insulation resistance> 100MΩ> 100MΩ
5, Accuracy in 1 ~ 60L / MIN ± 2% in line
6, Flow pulse characteristics F = (0.55 * Q) Q = L / Min meet
7, low temperature test at -20 ° C temperature set after 72h, at room temperature for 1h, the first measurement accuracy within ± 5% value in line
8, high temperature test temperature at 85 ° C placed after 72h, at room temperature for 1h, the first measurement accuracy within ± 5% value
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxx96f";
#include <ESP8266_Lib.h>
int ThermistorPin = 0;
int SpotPin = 1;
int UvbPin = 2;
int Vo;
int lux1;
int lux2;
float R1 = 10000;
float logR2, R2, T, Tc, Tf;
float c1 = 1.009249522e-03, c2 = 2.378405444e-04, c3 = 2.019202697e-07;
char ssid[] = "Fxxxxxxxxxxxxxxxx";
char pass[] = "xxxxxxxxxxxxxxx";
#define EspSerial Serial
SoftwareSerial softSerial(10, 11); // RX, TX
// Your ESP8266 baud rate:
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
// in Blynk app writes values to the Virtual Pin V1
BLYNK_WRITE(V1)
// process received value
void myTimerEvent()
Blynk.virtualWrite(V1, millis() / 50000);
Blynk.virtualWrite(V2, millis() / 50000);
Blynk.virtualWrite(V3, millis() / 50000);
uint32_t baud = 115200;
Serial.begin(baud);
softSerial.begin(baud);
Serial.print("SETUP!! @");
Serial.println(baud);
// Set ESP8266 baud rate
lux2=analogRead(UvbPin);
lux1=analogRead(SpotPin);
Vo = analogRead(ThermistorPin);
R2 = R1 * (1023.0 / (float)Vo - 1.0);
logR2 = log(R2);
T = (1.0 / (c1 + c2*logR2 + c3*logR2*logR2*logR2));
Tc = T - 273.15;
Tf = (Tc * 9.0)/ 5.0 + 32.0;
Serial.print(Tf);
Serial.print(" F; ");
Serial.print(Tc);
Serial.println(" C");
Blynk.virtualWrite(1,Tc ); //pin virtuale lampada temp
Blynk.virtualWrite(2,lux1 ); //pin virtuale lampada temp
Blynk.virtualWrite(3,lux2 ); //pin virtuale lampada temp
char auth[] = "**";
int SpotPin = 1;
int UvbPin = 2;
int Vo;
int lux1;
int lux2;
float R1 = 10000;
byte sensorInterrupt = 0; // 0 = digital pin 2
byte sensorPin = 4;
// The hall-effect flow sensor outputs approximately 4.5 pulses per second per
// litre/minute of flow.
float calibrationFactor = 0.55;
volatile byte pulseCount;
float flowRate;
int flowMilliLitres;
float totalMilliLitres;
float totalpour;
unsigned long oldTime;
char ssid[] = "**-1-EAgN0OZffijm";
char pass[] = "***";
BLYNK_WRITE(V1)
void myTimerEvent()
Blynk.virtualWrite(V4, millis() / 50000);
Serial.begin(baud);
pinMode(sensorPin, INPUT);
digitalWrite(sensorPin, HIGH);
pulseCount = 0;
flowRate = 0.0;
flowMilliLitres = 0;
totalMilliLitres = 0;
oldTime = 0;
// The Hall-effect sensor is connected to pin 2 which uses interrupt 0.
// Configured to trigger on a FALLING state change (transition from HIGH
// state to LOW state)
attachInterrupt(sensorInterrupt, pulseCounter, FALLING);
logR2 = log(R2);
Tc = T - 273.15;
Serial.print(Tf);
Serial.print(Tc);
if((millis() - oldTime) > 1000) // Only process counters once per second
// Disable the interrupt while calculating flow rate and sending the value to
// the host
detachInterrupt(sensorInterrupt);
// Because this loop may not complete in exactly 1 second intervals we calculate
// the number of milliseconds that have passed since the last execution and use
// that to scale the output. We also apply the calibrationFactor to scale the output
// based on the number of pulses per second per units of measure (litres/minute in
// this case) coming from the sensor.
flowRate = ((1000.0 / (millis() - oldTime)) * pulseCount) / calibrationFactor;
// Note the time this processing pass was executed. Note that because we've
// disabled interrupts the millis() function won't actually be incrementing right
// at this point, but it will still return the value it was set to just before
// interrupts went away.
oldTime = millis();
// Divide the flow rate in litres/minute by 60 to determine how many litres have
// passed through the sensor in this 1 second interval, then multiply by 1000 to
// convert to millilitres.
flowMilliLitres = (flowRate / 60) * 1000;
// Add the millilitres passed in this second to the cumulative total
totalMilliLitres += flowMilliLitres;
totalpour =(20 - (totalMilliLitres / 1000));
// Print the cumulative total of litres flowed since starting
Serial.print(" Keg Remaining: ");
Serial.print(totalpour, 2);
Serial.println(" Litres ");
// Reset the pulse counter so we can start incrementing again
pulseCount = 0;
// Enable the interrupt again now that we've finished sending output
Blynk.virtualWrite(4,totalpour ); //pin virtuale lampada temp
Insterrupt Service Routine
void pulseCounter()
// Increment the pulse counter
pulseCount++;
char auth[] = "**************************************";
int SpotPin = 1;
int UvbPin = 2;
int Vo;
int lux1;
int lux2;
float R1 = 10000;
byte sensorPin = 4;
float calibrationFactor = 4.8;
float flowRate;
float totalpour;
char ssid[] = "*****************";
char pass[] = "******************";
BLYNK_WRITE(V1)
void myTimerEvent()
Blynk.virtualWrite(V1, millis() / 100000);
Blynk.virtualWrite(V2, millis() / 100000);
Blynk.virtualWrite(V3, millis() / 100000);
Blynk.virtualWrite(V4, millis() / 100000);
Serial.begin(baud);
pulseCount = 0;
flowRate = 0.0;
oldTime = 0;
logR2 = log(R2);
Tc = T - 273.15;
// the host
oldTime = millis();
pulseCount = 0;
Blynk.virtualWrite(4,flowRate*60 ); //pin virtuale flusso per minuto
void pulseCounter()
pulseCount++;
I’m surprised when you say it works perfectly with this huge Baudrate…
And please… your code looks like Arduino world, not Blynk style… Follow @Costas’ recommendations…
And what do you think this code does in your sketch?
void myTimerEvent()
int SpotPin = 1;
int UvbPin = 2;
int Vo;
int lux1;
int lux2;
float R1 = 10000;
byte sensorPin = 4;
float flowRate;
float totalpour;
#define ESP8266_BAUD 9500
BLYNK_WRITE(V1)
Serial.begin(baud);
pulseCount = 0;
flowRate = 0.0;
oldTime = 0;
void pulseCounter()
pulseCount++;
void myTimerEvent()
logR2 = log(R2);
Tc = T - 273.15;
// the host
oldTime = millis();
pulseCount = 0;
I notice you still have this in your sketch but you have “hidden” it amongst other code. What do you think this code does and why do you have it in your sketch? If you don’t know the answer simply say so but don’t ignore our questions if you want to move forward.
Rather expect Blynkers to debug your code you need to do comprehensive testing and if you can’t find the bugs give a detailed description of what you are trying to do, what results you expected and what results you actually received. Rather than a catch all “does my sketch have any bugs?”.
I think this sketch tells you to write the value on v1 once per second. Right? I’m ignorant of programming and even in english. Go with goole translator so i apologize
int SpotPin = 1;
int UvbPin = 2;
int Vo;
int lux1;
int lux2;
float R1 = 10000;
byte sensorPin = 4;
float flowRate;
float totalpour;
BLYNK_WRITE(V1)
Serial.begin(baud);
pulseCount = 0;
flowRate = 0.0;
oldTime = 0;
timer.setInterval(5000L, myTimerEvent);
void pulseCounter()
pulseCount++;
void myTimerEvent()
logR2 = log(R2);
Tc = T - 273.15;
Blynk.virtualWrite(3,lux2); //pin virtuale lampada temp
// the host
oldTime = millis();
pulseCount = 0;
By analyzing the line I do not understand what it is for. that all right?
So something like “Arduino millis” as a search term in Google will give you a good idea of what the code does. Use the same format for any code you don’t understand.
Almost all MCU’s start an internal “clock” when they are reset and the clock starts at time zero. So the millis() function tells you how long the MCU has been running and is commonly referred to as uptime. millis as the name suggests is measured in milliseconds so quite often you will see millis() / 1000 to show the uptime seconds and it’s very rare you would see millis() / 100000.
sends the uptime in 100th’s of a second to V1 widget, then send the uptime in 100th’s of a second to V2 widget etc.
Totally useless information for almost all projects and you should remove the 4 lines of code from your sketch.
The reason the PUSH_DATA example uses millis() is because it’s an inbuilt “sensor” that all MCU’s have rather than temperature, light or wind sensors that some Blynkers will have but many will not.
