App not working
I’m getting request timeout while trying to login to my account. It happens after the button changes from connecting to syncing.
Which OS do you use?
Thanks for reply Im using iOS 8.4
I have same problem today. My iOS is 8.3. Err msg: kACNetworkManagerError Domain error -2
and other msg:
Server don’t respond in time. Connection to Inet is fine and checked of course. It seems that device is connected via port 8442.
The problem is when App try to Syncing Profile.
Could you please try connect via IP 45.55.195.102 and tell us if that helps?
tried on port 8443 but error msg returned: Can not connect to server. Try later. :wink:
port 8443 is for Applications only. for hardware it is 8442
yes I know. Problem is between iOS App and Blynk Cloud. Connection between device and cloud on 8442 is working fine.
@roky did you try IP 45.55.195.102?
If you mean on Blynk App on iOS - yes. 45.55.195.102:8443 at Custom section of App.
@roky so, same error?
yes. this one: Can not connect to server. Try later.
After hit login: Profile Conflict. Profile on this device is not synced with server. Which version should be used? Use local profile OR Use server profile.
Both option is not working.
Guys, please give me your emails.
@roky @conkerkh
Fixed. Please try again and tell me if all ok.
Its perfect Thanks a lot:)
Guys
I have the same profile conflict problem (IOS 8.3 and IOS 8.4), my email is the same as the one set for my account for this community forum, would you mind give it a try ?
thanks
Sorry, just tested it works !!! was not working since 5/6 day, thks
