Before creating the topic
I am using :
• Arduino UNO with Ethernet Shield
• Android + version 5.1.1
• local server
• Blynk Library version
• Add your sketch code. Code should be formatted as example below.
#include <Ethernet.h>
#include <DHT.h>
char auth[] = "code";
IPAddress server_ip (192, 168, 43, 49);
// Mac address should be different for each device in your LAN
byte arduino_mac[] = { 0xDE, 0xED, 0xBA, 0xFE, 0xFE, 0xED };
IPAddress arduino_ip (192,168,137,88);
IPAddress dns_ip (192, 168, 43, 1);
IPAddress gateway_ip (192, 168, 43, 1);
IPAddress subnet_mask(255, 255, 255, 0);
#define W5100_CS 10
#define SDCARD_CS 4
#define DHTPIN 7 // What digital pin we're connected to
#define DHTTYPE DHT22 // DHT 22
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
pinMode(SDCARD_CS, OUTPUT);
digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
Blynk.begin(auth, server_ip, 9443, arduino_ip, dns_ip, gateway_ip, subnet_mask, arduino_mac);
//You can also specify server:
//Blynk.begin(auth);
//Blynk.begin(auth, "localhost name", 80);
//Blynk.begin(auth, IPAddress(192,168,1,100), 8080);
dht.begin();
