I am making a Raspberry Pi weather station that uploads its data using Blynk. I recently discovered that the weather station is only uploading data to the Blank app when the app is running. Shortly after I close the app (hit the home button), the weather station stops uploading data. This leads to my Supercharts missing large chunks of data. I also have a lightning detector set up to send notifications with a time stamp when it detects a lightning strike; however, I only receive the notification when I open the app and the time stamp isn’t when the strike occurred but rather when I opened the app. I am using the python Blynk library. I am also using the latest iOS app. I would greatly appreciate any help as I am new to coding and Blynk. Here is my code for the Raspberry Pi.
import BlynkLib_Outdoor
import time
import Adafruit_TCS34725
from Adafruit_BME280 import *
from RPi_AS3935 import RPi_AS3935
import SI1145.SI1145 as SI1145
import RPi.GPIO as GPIO
from datetime import datetime
import smbus
BLYNK_AUTH = 'This is where my token normally is'
# Initialize Blynk
blynk = BlynkLib_Outdoor.Blynk(BLYNK_AUTH)
# Initialize Lightning detector
as3935 = RPi_AS3935(address=0x03, bus=1)
as3935.set_indoors(True)
as3935.set_noise_floor(0)
time.sleep(0.005)
as3935.calibrate(tun_cap=2)
time.sleep(0.005)
as3935LastInterrupt = 0
as3935LightningCount = 0
as3935LastDistance = 0
as3935LastStatus = ""
GPIO.setmode(GPIO.BCM)
as3935Interrupt = False
def process_as3935_interrupt():
global as3935Interrupt
global as3935, as3935LastInterrupt, as3935LastDistance, as3935LastStatus
reason = as3935.get_interrupt()
time.sleep(0.003)
as3935LastInterrupt = reason
if reason == 0x00:
now = datetime.now().strftime('%H:%M:%S - %m/%d')
as3935LastStatus = "Spurious Interrupt %s" % now
elif reason == 0x01:
as3935LastStatus = "Noise Floor too low - adjusting (%s)" % now
as3935.raise_noise_floor()
elif reason == 0x04:
as3935LastStatus = "Disturber detected - masking (%s)" % now
as3935.set_mask_disturber(True)
elif reason == 0x08:
distance = as3935.get_distance()
as3935LastDistance = distance
as3935LastStatus = "Lightning Detected " + str(distance) + "km away. (%s)" % now
blynk.virtual_write(6, as3935LastStatus)
blynk.notify(as3935LastStatus)
def handle_as3935_interrupt(channel):
blynk.virtual_write(6, "as3935 Interrupt")
as3935Interrupt = True
as3935pin = 17
GPIO.setup(as3935pin, GPIO.IN)
GPIO.add_event_detect(as3935pin, GPIO.RISING, callback=handle_as3935_interrupt)
# Other sensors
@blynk.VIRTUAL_READ(1)
def v1_read_handler():
sensor_1 = BME280(t_mode=BME280_OSAMPLE_8, p_mode=BME280_OSAMPLE_8, h_mode=BME280_OSAMPLE_8)
degrees = sensor_1.read_temperature_f()
blynk.virtual_write(1, '{0:0.1f}'.format(degrees))
@blynk.VIRTUAL_READ(2)
def v2_read_handler():
sensor_2 = BME280(t_mode=BME280_OSAMPLE_8, p_mode=BME280_OSAMPLE_8, h_mode=BME280_OSAMPLE_8)
# atm = sensor.read_pressure_atm()
pascals = sensor_2.read_pressure()
hectopascals = pascals / 100
blynk.virtual_write(2, '{0:0.0f}'.format(hectopascals))
@blynk.VIRTUAL_READ(3)
def v3_read_handler():
sensor_3 = BME280(t_mode=BME280_OSAMPLE_8, p_mode=BME280_OSAMPLE_8, h_mode=BME280_OSAMPLE_8)
humidity = sensor_3.read_humidity()
blynk.virtual_write(3, '{0:0.1f}'.format(humidity))
@blynk.VIRTUAL_READ(4)
def v4_read_handler():
tcs = Adafruit_TCS34725.TCS34725(integration_time=Adafruit_TCS34725.TCS34725_INTEGRATIONTIME_154MS,
gain=Adafruit_TCS34725.TCS34725_GAIN_4X)
tcs.set_interrupt(False)
r, g, b, c = tcs.get_raw_data()
lux = Adafruit_TCS34725.calculate_lux(r, g, b)
blynk.virtual_write(4, lux)
@blynk.VIRTUAL_READ(5)
def v5_read_handler():
sensor_4 = SI1145.SI1145()
vis = sensor_4.readVisible()
IR = sensor_4.readIR()
uv = sensor_4.readUV()
uvindex = uv / 100.0
blynk.virtual_write(5, uvindex)
@blynk.VIRTUAL_READ(6)
def v6_read_handler():
if as3935Interrupt == True:
# Start Blynk
blynk.run()
