hello
i’ve such a probleme
the app didn’t even started after last update UPDATE 2.26.2
my phone is : Samsung galaxy J1 6 SM-J120H Android 5.1.1
after starting the app it stuck in the grey page of loading until it crash
i cleaned DATA and CACHE and not working
please fix it beceause i’ve a project to do with it
Please try to manually remove and install it again. Does that help?
i’ll try to
wait
I was about to post this issue as well…
I tried in two devices and thought I had a server issue, but once I realised my wall mount tablet still worked (older App) I realised it was the new App
Have you sent the crash report? As I do not see any new crash reports(
Doesn’t get that far… unless the Google one is what you are looking for? That is the only reporting option and I didn’t send anything for that…
EDIT OK I just did for kicks
Guys are you both on Android 5 ?
I’m preparing a build for you based on android 5 simulator test.
Android 4.4.2
I did reload it on my Android 8 phone… long enough to confirm it works… then it burnt my eyes out looking at all the cropped text
Im on 5.1.1 - sony xperia z ultra. There is no problem.
with last update ?
Yeah. I installed it a few minutes ago from play store
Guys please check this build - it should fix you issue (if my android 5 simulator has the same issue)
Had you removed previous build before this one?
Yes.
