Hi all!
I’m having Blynk Local Server running on Raspberry Pi3, also a couple of ESP8266 connected as a clients. I faced with the issue of server API: when I’m trying to get /isHardwareConnected response, it is always true (also when ESP is turned off).
I’m using like this: https://local_ip:7882/auth_token/isHardwareConnected
What can be the reason?
Regards and respect, Max
