API And Tags
API work with Token So When i Create a Tag That pinned to a virtual PIN. i can’t access to the PIN with API so How do you solve this Problem?
unfortunately, not all widgets / app functionalities are available from api.
for example: zergba, terminal, joystick etc.
afaik you can read / write only the virtual and digital pins via api.
but maybe @Dmitriy can provide more info…
this is so necessary for me that i have access to send group command(Tag), (i.e. when my phone turn off or etc.) i know that i can do this with Bridge but i ask about other simple solution.
