Any solution to this Blynk/Board problem
When I upload a default/example code to my Sparkfun ESP8266 Thing Dev Board from Arduino, it works fine. I can turn off and on the LED on the board with GP5 in Blynk. Everything works fine.
But when I upload my specific code (its a code to control a LED light from using Blynk), it goes offline. I have the same auth token in both codes, as well as the SSID and Pass. Any solutions/recommendations? I can post the codes if anyone wants to see
