Hello every body ,
I’m a new blynk user and I would to know if there is a solution to install blynk server on nodemcu.
I just read an article on how to install java on ESP8266
but I’m not an expert !!
thank you for your help
Hello every body ,
Even were it possible, I highly doubt it would have the horsepower, and definitely not the storage capacity to be usable.
An RPi Zero W will be about the same physical size, and only slightly higher cost, but and fully functional and supported.
Basically, feel free to try, but don’t expect any solid support
thank you so much Gunner
I think I’d better get a RPI Zero !!
Don’t forget the W version… you will NEED that built in WiFi for a server
JavaScript is something totally different from the Java that Blynk server requires
Picky details OK, I probably should have caught that, but… totes newb Linux dude
Check this one also:
Orange Pi Zero 512Mb:
http://s.aliexpress.com/qiE3MBF7
I’ve got one and works perfectly
Or rent one for less than a $1 a month with 1GB RAM and 20GB storage.
thank you I’ve got one too !!!
