App Android: version 2.23.1
Insert new zeRGBa widget and edit config.
would not it be better if the default range is 0-255? as here
Best regards
Best regards
Yep, sure it should be 0-255, it will be fixed in the next release
Considering that ESP8266 is becoming so prevalent, 0-1023 is the ideal PWM range for that device… but then the LED widget still runs on 0-255
