I made 2 simple programs to show temperature readings from 2 different esp8266’s. They work fine from the pc blynk website but when I open the android app on my galaxy s22 ultra, the names of both programs show up but there is no way to see the data.
the Blynk App.
NOTE:
BlynkTimer provides SimpleTimer functionality:
http://playground.arduino.cc/Code/SimpleTimer
App project setup:
Value Display widget attached to Virtual Pin V5
#define BLYNK_TEMPLATE_ID "TMPLhtkFQC9t"
#define BLYNK_DEVICE_NAME "temperature 2"
#define BLYNK_AUTH_TOKEN "BbwnS01jHejC7Kl5PcMOhKB8p29fopi-"
#include <OneWire.h>
char ssid[] = "xxxxxxx";
char pass[] = "xxxxxxx";
#define ONE_WIRE_BUS 2 // DS18B20 on arduino pin2 corresponds to D4 on physical board "D4 pin on the ndoemcu Module"
DallasTemperature DS18B20(&oneWire);
float temp;
float Fahrenheit=0;
void myTimerEvent()
DS18B20.begin();
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
timer.setInterval(1000L, getSendData);
void getSendData()
DS18B20.requestTemperatures();
temp = DS18B20.getTempCByIndex(0); // Celcius
Fahrenheit = DS18B20.toFahrenheit(temp); // Fahrenheit
//Serial.println(temp);
Serial.println(Fahrenheit);
//Blynk.virtualWrite(V3, temp); //virtual pin V3 celcius
Blynk.virtualWrite(V4, Fahrenheit); //virtual pin V4 fahrenheit
