I can not operate my dashboards because i get stuck, with those circles moving without any response.
android app is not working as usual, it does not let me see my dashboards. it gets stuck
You can’t see the dashboard if your router thinks the Blynk server is still down. Even with a reboot of the router you might still have to wait for the DNS to populate. If you use 8.8.8.8 and 8.8.4.4 for DNS you might have more success as Google’s DNS normally populate quicker than those of ISP’s.
Im using an arduino Yun with 3G connection
Are you using latest Blynk libraries? Did you hardcode IP/host?
Yes im using the latest blynk library
now, everything works normally. please this never should happen again. I will recomend blynk for bussiness
