http://twitter.com/blynk_app
This example runs directly on NodeMCU.
Please be sure to select the right NodeMCU module
in the Tools -> Board menu!
For advanced settings please follow ESP examples :
- ESP8266_Standalone_Manual_IP.ino
- ESP8266_Standalone_SmartConfig.ino
- ESP8266_Standalone_SSL.ino
Comment this out to disable prints and save space/
Rui Santos/
Complete project details at http://randomnerdtutorials.com/
#include <Adafruit_Sensor.h>
/********************** Frontdoor *****************************************************************/
const int switchReed = 5; // Frontdoor D1 = gpio 5
int doorreedCounter = 0; // counter for the number of door openings
int doorreedState = 0; // current state of the Door
int lastdoorreedState = 0; // previous state of the Door
/********************** Garagedoor ****************************************************************/
const int switch1Reed = 12; // Garagedoor D6 = gpio 12
int doorreed1Counter = 0; // counter for the number of door openings
int doorreed1State = 0; // current state of the Door
int lastdoorreed1State = 0; // previous state of the Door
/********************** Blynk Athentication Token *************************************************/
char auth[] = "iKklxMOUfksdjfhsdgfd_Mk2hXqxH7bi";
/********************** WiFi credentials **********************************************************/
char ssid[] = "Zi*********";
char pass[] = "J*******1";
/********************** Relay controlled with D7 **************************************************/
int relay = 13; // relay connected to pin D7 gpio 13
volatile byte relayState = LOW; //relay state
/********************** Pir HC-SR501 **************************************************************/
int PIRInterrupt = 4; // PIR Motion Sensor is connected to D2 gpio 4
int relay1 = 14; // relay connected to pin D7 gpio 13
volatile byte relayState1 = LOW; //relay state
int PIRInterrupt1 = 0; // PIR Motion Sensor is connected to D3 gpio 0
/********************** Timer for Relay Stay on ***************************************************/
long lastDebounceTime = 0;
long debounceDelay = 20000; //20 seconds
/********************** Blynk Timer event *********************************************************/
BlynkTimer timer; // Announcing the timer
/********************** InitVariables *************************************************************/
int Alarm_arm_disarm; //arm or disarm the alarm
int Restart; // restart the wemos32
/********************** Sync status buttons to App ************************************************/
BLYNK_CONNECTED() {
Blynk.syncVirtual(V10);
/********************** Activate Alarm True App ***************************************************/
BLYNK_WRITE(V10) {
Alarm_arm_disarm = param.asInt();
/********************** Reset esp8266 True App ****************************************************/
BLYNK_WRITE(V11) {
Restart = param.asInt();
/********************** Frontdoor switchReed V0-D1-gpio5 ******************************************/
void myTimerEvent()
if (Alarm_arm_disarm == 1) {
doorreedState = digitalRead(switchReed);
// compare the buttonState to its previous state
if (doorreedState != lastdoorreedState) {
// if the state has changed, increment the counter
if (doorreedState == LOW) {
// if the current state is LOW then the button
// is pressed wend from off to on:
doorreedCounter++;
Blynk.virtualWrite(V0, HIGH);
Serial.print("FrontDoor Close");
Serial.println(doorreedState);
Serial.println(doorreedCounter);
else {
// wend from on to off:
Serial.print("FrontDoor Open");
Blynk.virtualWrite(V0, LOW);
// save the current state as the last state,
//for next time through the loop
lastdoorreedState = doorreedState;
/********************** Garagedoor switch2Reed V2-D8-gpio15 ***************************************/
void myTimerEvent1()
doorreed1State = digitalRead(switch1Reed);
if (doorreed1State != lastdoorreed1State) {
if (doorreed1State == LOW) {
doorreed1Counter++;
Blynk.virtualWrite(V2, HIGH);
Serial.print("GarageDoor Close");
Serial.println(doorreed1State);
Serial.println(doorreed1Counter);
else {
Serial.print("GarageDoor Open");
Blynk.virtualWrite(V2, LOW);
lastdoorreed1State = doorreed1State;
/********************** Restart nodemmcu with button **********************************************/
void myTimerEvent2()
if (Restart == 1) {
ESP.restart();
// Pin for relay module set as output
pinMode(relay, OUTPUT);
pinMode(relay1, OUTPUT);
digitalWrite(relay, HIGH);
digitalWrite(relay1, HIGH);
// PIR motion sensor set as an input
pinMode(PIRInterrupt, INPUT);
// Triggers detectMotion function on rising mode to turn the relay on, if the condition is met
attachInterrupt(digitalPinToInterrupt(PIRInterrupt), detectMotion, RISING);
pinMode(PIRInterrupt1, INPUT);
attachInterrupt(digitalPinToInterrupt(PIRInterrupt1), detectMotion1, RISING);
//Blynk.begin(auth, ssid, pass);
Blynk.begin(auth, ssid, pass, IPAddress(192, 168, 178, 222), 8080);
pinMode(switchReed, INPUT_PULLUP);
pinMode(switch1Reed, INPUT_PULLUP);
timer.setInterval(1000L, myTimerEvent1);
timer.setInterval(1000L, myTimerEvent2);
timer.run(); // running timer every second
// If 20 seconds have passed, the relay is turned off
if((millis() - lastDebounceTime) > debounceDelay && relayState == HIGH){
relayState = LOW;
Serial.println("Motion detection is OFF");
Serial.println("Relay is LOW");
delay(50);
void detectMotion() {
Serial.println("Motion");
if(relayState == LOW){
digitalWrite(relay, LOW);
relayState = HIGH;
Serial.println("Motion detection is ON");
Serial.println("Relay is HIGH");
lastDebounceTime = millis();
void detectMotion1() {
Serial.println("Motion 1");
if(relayState1 == LOW){
digitalWrite(relay1, LOW);
relayState1 = HIGH;
Serial.println("Motion detection 1 is ON");
Serial.println("Relay 1 is HIGH");
