Agriculture Automation System...... Problem in PushButton switches while runing the project
What kind of relays do you use? I have two different types. One switches on LOW signal and one on HIGH, maybe it’s something like that?
relays are activated when it receives high signal form arduino board…
Just checking :slight_smile: I’ve heard weirder bugs, lol.
And what happens if you attach a simple LED to the Pin? Does that work or does that also not work? I’m really confused as to why your things are not working because they should work bij all means (your code looks pretty much ok).
yaa i try instate of relay i connect led and check it, But it is not working…
some time it get on after 5-6 min but not off until i reset board…
That’s really weird. The best I can conclude is that there is too much latency to the server. You are using the cloud service right, not the local server?
