Hi, I need your help.
I have an arduino with ethernet shiel to control 8 digital outputs with relay module. If I connect via USB or 5Vdc adapter, when I remove the voltage supply and re-set the voltage supply, I have to press the reset button on the board so that I can connect with blink.
Is there any way to make it automatic?
I appreciate your help.
i have the same problem.
What does Serial Monitor show?
Precisely why Arduino are you using?
Do you have an Arduino Due?
I’ve got one and I had to do a small change at the board to avoid this issue.
