Adding Timer to my skech stopps it at the beggining
Im running Arduino Uno and Esp8266
Adding BlynkTimer causes my sketch to stop on Blynk.begin function, and not processing any further. It could be something with other libraries that I’m using
If I dont include RTClib it works fine.
I think this post describes a problem very similar to mine but he is running on some other hardware SOLVED: Any timer kills my sketch (ESP core version)
This is my code :
I know it is kind of messy but I will try to anwser any questions about it
#include <ESP8266_Lib.h>
#include <WidgetRTC.h>
char auth[] = "LRJWdn_W0OOln4_5KmGpZRwnsEB_i9Ev";
char ssid[] = "Router Local WIFI"; //RouterTOTO 2.4GHz
char pass[] = "malina123";//malina123
#include <SoftwareSerial.h>
SoftwareSerial EspSerial(5, 6); // RX, TX
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
//WidgetRTC Wrtc;
#include <ShiftRegister74HC595.h>
#include <math.h>
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 Hrtc;
ShiftRegister74HC595<3> sr (2, 3, 4);
byte zero = 0;
const int  minusButton = 8;
const int  plusButton = 9;
static int secPins [2][4] = {{0, 1, 2, 3}, {4, 5, 6, 7}}; // first units then dec
static int minPins [2][4] = {{8, 9, 10, 11}, {12, 13, 14, 15}};
static int hourPins [2][4] = {{16, 17, 18, 19}, {20, 21, 22, 23}};
DateTime last = (2020, 03, 06, 00, 00, 00, 00);
int mode = 1;
byte decToBcd(byte val) {
  return ((val / 10 * 16) + (val % 10));
byte bcdToDec(byte val) {
  return ((val / 16 * 10) + (val % 16));
void setDateToRTC(byte seconde, byte minutee, byte houre, byte weekDaye, byte monthDaye, byte monthe) {
  Wire.beginTransmission(DS1307_ADDRESS);
  Wire.write(zero); //stop Oscillator
  Wire.write(decToBcd(seconde));
  Wire.write(decToBcd(minutee));
  Wire.write(decToBcd(houre));
  Wire.write(decToBcd(weekDaye));
  Wire.write(decToBcd(monthDaye));
  Wire.write(decToBcd(monthe));
  Wire.write(decToBcd(byte(2021)));
  Wire.write(zero); //start
  Wire.endTransmission();
void nixieWrite(int pins[], uint8_t value) { // gets set of pins for nixie digit and number, and sends it to
  sr.set(pins[3], (value & 0x08) >> 3);
  sr.set(pins[2], (value & 0x04) >> 2);
  sr.set(pins[1], (value & 0x02) >> 1);
  sr.set(pins[0], value & 0x01);
void ClockHourWrite() { // get time and prints on the clocks digits
  DateTime now = Hrtc.now();
  //Serial.println(String(now.second()) + ":" + now.minute() + ":" + now.hour());
  //Serial.println(now.second());
  nixieWrite(secPins[0], now.second() % 10); //sec unit
  if (floor(last.second() / 10) != floor(now.second() / 10)) {
    nixieWrite(secPins[1], floor(now.second() / 10)); //sec dec
  if (last.minute() % 10 != now.minute() % 10) {
    nixieWrite(minPins[0], now.minute() % 10);
  if (floor(last.minute() / 10) != floor(now.minute() / 10)) {
    nixieWrite(minPins[1], floor(now.minute() / 10));
  if (last.hour() % 10 != now.hour() % 10) {
    nixieWrite(hourPins[0], now.hour() % 10);
  if (floor(last.hour() / 10) != floor(now.hour() / 10)) {
    nixieWrite(hourPins[1], floor(now.hour() / 10));
  last = now;
void ClockDateWrite() { // get time and prints on the clocks digits
  Serial.println(String(now.day()) + ":" + now.month() + ":" + now.year() % 2000);
  if (last.day() != now.day()) {
    nixieWrite(secPins[0], (now.year() % 2000) % 10);
    nixieWrite(secPins[1], floor((now.year() % 2000) / 10));
    nixieWrite(minPins[0], now.month() % 10);
    nixieWrite(minPins[1], floor(now.month() / 10));
    nixieWrite(hourPins[0], now.day() % 10);
    nixieWrite(hourPins[1], floor(now.day() / 10));
    last = now;
void ClockCustomWrite() {
  //This will be custom number to display
void clockLoop() {
  Serial.println("tick");
  //if(mode==1)
  ClockHourWrite();
  //else if(mode==2)
  //ClockDateWrite();
  //else //mode 3
  //ClockCustomWrite();
#ifndef ESP8266
  while (!Serial); // wait for serial port to connect. Needed for native USB
#endif
  /*if (! Hrtc.begin()) {
    Serial.println("Couldn't find RTC");
    Serial.flush();
    abort();
  delay(100);
  Serial.println("connected up!");
  Serial.println(Hrtc.begin());
  timer.setInterval(1000L, clockLoop);//every second call clockloop function
BLYNK_WRITE(V10) // V10 is the number of Virtual Pin
  if (param.asInt() == mode) {
BLYNK_WRITE(V9)// set time to RTC from Blynk server
  if (param.asInt() == 1) {
    Serial.println("settingTime");
BLYNK_CONNECTED() {
  Blynk.syncAll();  // Synchronize hardware with App widgets when connected
  //Wrtc.begin();
