Adding Push Notification
So I have been playing around with the Blynk app and i must say it is wonderful. The only trouble I am having is to get the Push notifications to work correctly or at all. Here is the program I am using
#include <DHT.h>
char auth[] = "9270f80324744ea5807b2xxxxxxxxxx";
char ssid[] = "xxxxxxx";
char pass[] = "xxxxxxx";
#define DHTPIN 2          // What digital pin we're connected to
#define DHTTYPE DHT11     // DHT 11
//#define DHTTYPE DHT22   // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21   // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
  float h = dht.readHumidity();
  if (isnan(h) || isnan(t)) {
    return;
  Blynk.virtualWrite(V5, h);
  Blynk.virtualWrite(V6, t);
  dht.begin();
i hope someone can help me. thanks
Hello. But you don’t use any push notifications in your code. Do you have eventor?
i am using ios. anyway the problem already solved
thanks for the respond
