Adding hardware support yourself
I’m new to Blynk and I’m a very experienced engineer (BSEE with 35 years experience as a software engineer).
So, when I looked for Blynk hardware support I see the usual arduino, etc, type hardware. However, I’d like to know if I wanted to add support for a custom board or some lesser used board, how would I go about adding support myself. I’m sure there are many other engineers like myself more than capable of doing this who would love to know how. Is there a link where I can see how to add custom hardware support to blynk myself??? Appreciate any help in advance…thank you.
You can take a look here: https://github.com/blynkkk/blynk-library/blob/master/docs/Implementing.md
Also, @vshymanskyy can help if you have questions
It would be great if you could share your work back to community.
Thanks!
Thank you so much. I’ve not decided to what extent I want to use this or not, but if I do, rest assured that I’ll return anything that I do to the community.
Hi. Which exactly hardware are you using?
