I wonder why it s not possible to add a widgte with used pin. I would like, for example to have some value display like temperatur on two different tabs. But now i have to assign a differnt virtual pin and wite code, instead of just using the same VP .
We will implement it in future. Thanks for idea.
Is this still being considered? It would be really useful to be able to display a value in different places.
For example, with multiple tabs as suggested by @johanan, or putting the Graph widget side-by-side with a Gauge or Value Display widget.
As of now, you’d need to code on the arduino/esp board so that it sends the same value on multiple pins, which seems a waste of pins and code.
Is this still on the road map? I’m happy to create a ticket with some use cases and test scenarios if that will help progress it along
