http://twitter.com/blynk_app
This example shows how to synchronize Button widget
and physical button state.
App project setup:
Button widget attached to V2 (Switch mode)
#include <Ethernet.h>
char auth[] = “YourAuthToken”;
#define W5100_CS 10
#define SDCARD_CS 4
// Set your LED and physical button pins here
const int ledPin = 7;
const int btnPin = 8;
void checkPhysicalButton();
int ledState = LOW;
int btnState = HIGH;
// Every time we connect to the cloud…
BLYNK_CONNECTED() {
Blynk.syncVirtual(V2);
// Alternatively, you could override server state using:
//Blynk.virtualWrite(V2, ledState);
// When App button is pushed - switch the state
BLYNK_WRITE(V2) {
ledState = param.asInt();
digitalWrite(ledPin, ledState);
if (digitalRead(btnPin) == LOW) {
if (btnState != LOW) {
// Toggle LED state
ledState = !ledState;
// Update Button Widget
btnState = LOW;
btnState = HIGH;
pinMode(SDCARD_CS, OUTPUT);
digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
Blynk.begin(auth);
//Blynk.begin(auth, “blynk-cloud.com”, 8442);
//Blynk.begin(auth, IPAddress(192,168,1,100), 8442);
pinMode(ledPin, OUTPUT);
pinMode(btnPin, INPUT_PULLUP);
// Setup a function to be called every 100 ms
timer.setInterval(100L, checkPhysicalButton);
