About the Notification function (Cannot receive notification in the mobile phone)
Hi everyone. I’m new to Blynk. Please forgive me, my English is not good.
I’ve just known this app for few days and found this app is awesome. It solves a lot of problems.
I tried different functions in the example and encountered a problem while using the notification widget.
I made use of the simplest version of the code provided in the example to trigger a notification in start up. I do add a notification widget in the phone. I can only recieve notification when the device if offline (durint reset). However, I can never receive any notificaiton during start up (I used the code Blynk.notify(“xxxx”).
Remarks:
  1. Use both iOS and Android separately
  2. Uninstall and install the app again
  3. Delete and Add the notification wiget again. (email widget as well)
I really want to solve this problem because I can make use of IFTTT or any other app to trigger other services.
Thanks all~
Regards,
Chung
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  You’ll need:
   - Blynk App (download from AppStore or Google Play)
   - WeMos D1 board
  started. Think of them as LEGO bricks  and combine them as you wish.
  example.
char auth[] = "my auth token";
char ssid[] = "xxx";
char pass[] = "xxxxxxxxx";
  Blynk.notify("Hey, Blynkers! My hardware can push now!");
  Blynk.email("xxxxxx@gmail.com", "Subject", "Your message goes here");
  Blynk.tweet("Hey, Blynkers! My Arduino can tweet now!");
  Serial.println("AAA");
  // to avoid delay() function!
@pclam please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
Thanks for your reminder. I just amended.
What happens if you try the sketch builder example rather than trying to send a notification in void setup?
If I try the sketch builder example as shown below (by using the Simplest one but changing the auth token, ssid, and pwd), I can see wifi is connected in the serial monitor.
  You’ll need:
   - ESP8266 board
  example.
char auth[] = "xxxxxxxxxxxxxxxxxxx";
char ssid[] = "xxxxxx";
char pass[] = "xxxxxxxxxxxx";
Besides, I tried to make use of other examples, Virtual write, Push Data. Both of them works fine.
Does that mean that it’s not connecting to the Blynk server?
I guess my presentation is confusing, sorry about that. Below please find the details.
I guess it had been connected to Blynk server, since I can make use of the Blynk to control the LED on the D1 mini and get Analog data from the D1 mini.
[567] Connected to WiFi
[567] IP: 192.168.xxx.xxx
[567]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ / '/
//_, /////_
__/ v1.0.0-beta.3 on ESP8266
[648] Connecting to blynk-cloud.com:80
[775] Ready (ping: 38ms).
Uninstall this and install 0.6.1 instead.
May I know where should I reinstall it (v1.0.0-beta 3)? What does it refer to?
The board manager of ESP8266 or
The Blynk library or
The Arduino IDE itself?
Thanks.
It’s the Blynk library.
Dear Pete,
Problem Solved. You are awesome.
May I know that happens to v1.0.0-beta 3? It is a newer version, why doesn’t it support notification widget?
Regards,
Chung
It’s for the new version of Blynk which is in beta testing at the moment.
Notifications are handled differently in the new version.
I see. Thanks Pete.
Thanks for solving this problem for me. I stuck for few days. And thanks for your patience.
Really thanks!
Chung
