A slider switch with multiple states, where you can select the number of states would be great.
I have used a slider widget to do this but it’s not very accurate.
A menu widget can also be used, but normally people doesn’t think of a menu as a switch, although it really is, so a switch with set states would be better.
Try the Step Control Widget, many options, very accurate.
I use step widgets in almost all my project, but it’s a bad switch.
You should be able to look at a switch, and decide the position it’s in, like the simple button in Blynk.
Some times you need a switch with more than two states.
A virtual version of this would be great:
