A different way to activate the access point
No, this is my first time using this code.
We are managing to evolve, there were no more mistakes at the same point. Now I have an array error. I will post the Error.
//char mqtt_server[40];
//char mqtt_port[6] = "8080";
char blynk_token[34] = "Pd9SZNoijsyhegrtbkTitt-nOUkYIrnh";
    More code...
//mqtt_server = json["mqtt_server"];
//mqtt_port = json["mqtt_port"];
blynk_token = json["blynk_token"];   <------Error Here
exit status 1
incompatible types in assignment of 'ArduinoJson::Internals::JsonObjectSubscript<const char*>' to 'char [34]'
You need to sort-out your code formatting.
#include <FS.h>                   //this needs to be first, or it all crashes and burns...
#include <SPIFFS.h>
#include "processo.h"
#include "global.h"
#include <stddef.h>
#include <arduino.h>
#include "Controladores.h"
#include <WiFi.h>
#include "persistente.h"
#include <HTTPClient.h>
#include <DNSServer.h>
#include <WebServer.h>
#include "BlynkSimpleEsp32.h"
#include <WiFiManager.h>
#include <ArduinoJson.h>          //https://github.com/bblanchon/ArduinoJson
//char auth[] = "Pd9SZNodRX688FDh_kTitt-nOUkYIrna";
//char ssid[] = "Indka";
//char pass[] = "iub950962";
//define your default values here, if there are different values in config.json, they are overwritten.
char blynk_token[34] = "Pd9SZNodRX688FDh_kTitt-nOUkYIrna";
//flag for saving data
bool shouldSaveConfig = false;
#define BLYNK_WM_DEBUG    3
WidgetTerminal terminal(V10);
WiFiManager wifiManager;//Objeto de manipulação do wi-fi
extern Controladores SensoresAtuadores[MAXDEVICE];
extern Persistente persistente;
Processo &Processo::getInstance()
  static Processo _instance;
  return _instance;
void Processo::init()
  //Blynk.begin(auth, ssid, pass);
  //clean FS, for testing
  //SPIFFS.format();
  //read configuration from FS json
  Serial.println("mounting FS...");
  if (SPIFFS.begin()) {
    Serial.println("mounted file system");
    if (SPIFFS.exists("/config.json")) {
      //file exists, reading and loading
      Serial.println("reading config file");
      File configFile = SPIFFS.open("/config.json", "r");
      if (configFile) {
        Serial.println("opened config file");
        size_t size = configFile.size();
        // Allocate a buffer to store contents of the file.
        std::unique_ptr<char[]> buf(new char[size]);
        configFile.readBytes(buf.get(), size);
        StaticJsonBuffer<200> jsonBuffer;
        JsonObject& json = jsonBuffer.parseObject(buf.get());
        json.printTo(Serial);
        if (json.success()) {
          Serial.println("\nparsed json");
          Serial.println("failed to load json config");
    Serial.println("failed to mount FS");
  //end read
  // The extra parameters to be configured (can be either global or just in the setup)
  // After connecting, parameter.getValue() will get you the configured value
  // id/name placeholder/prompt default length
  //WiFiManagerParameter custom_mqtt_server("server", "mqtt server", mqtt_server, 40);
  //WiFiManagerParameter custom_mqtt_port("port", "mqtt port", mqtt_port, 8);
  WiFiManagerParameter custom_blynk_token("blynk", "blynk token", blynk_token, 32);
  //WiFiManager
  //Local intialization. Once its business is done, there is no need to keep it around
  //WiFiManager wifiManager;
  //set config save notify callback
  wifiManager.setSaveConfigCallback(saveConfigCallback);
  //add all your parameters here
  //wifiManager.addParameter(&custom_mqtt_server);
  //wifiManager.addParameter(&custom_mqtt_port);
  wifiManager.addParameter(&custom_blynk_token);
  //reset settings - for testing
  wifiManager.resetSettings();
  //set custom ip for portal
  wifiManager.setAPConfig(IPAddress(10,1,1,1), IPAddress(10,1,1,1), IPAddress(255,255,255,0));
  //set minimu quality of signal so it ignores AP's under that quality
  //defaults to 8%
  wifiManager.setMinimumSignalQuality();
  //sets timeout until configuration portal gets turned off
  //useful to make it all retry or go to sleep
  //in seconds
  //wifiManager.setTimeout(120);
  //fetches ssid and pass and tries to connect
  //if it does not connect it starts an access point with the specified name
  //here  "AutoConnectAP"
  //and goes into a blocking loop awaiting configuration
  if (!wifiManager.autoConnect("MEfEvaFaraAzzahra")) {
    Serial.println("failed to connect and hit timeout");
    delay(3000);
    //reset and try again, or maybe put it to deep sleep
    ESP.reset();
    delay(5000);
  Serial.println("connected...yeey :)");
  //read updated parameters
  //mqtt_server = custom_mqtt_server.getValue();
  //mqtt_port = custom_mqtt_port.getValue();
  blynk_token = custom_blynk_token.getValue();
  Blynk.config(blynk_token);
  Serial.println(blynk_token);
  //save the custom parameters to FS
  if (shouldSaveConfig) {
    Serial.println("saving config");
    JsonObject& json = jsonBuffer.createObject();
    //json["mqtt_server"] = mqtt_server;
    //json["mqtt_port"] = mqtt_port;
    json["blynk_token"] = blynk_token;
    File configFile = SPIFFS.open("/config.json", "w");
    if (!configFile) {
      Serial.println("failed to open config file for writing");
    json.printTo(configFile);
    configFile.close();
    //end save
void Processo::terminalClear() {
    terminal.clear();
void Processo::println(String text) {
     terminal.println(text);
     terminal.flush();
void Processo::print(String text) {
    terminal.print(text);
    terminal.flush();
void Processo::configModeCallback(WiFiManager *wm){
     Serial.println("Entrou no modo de configuração");
     Serial.println(WiFi.softAPIP());
     Serial.println(wm->getConfigPortalSSID());
void Processo::saveConfigCallback(){
     Serial.println("Configuração Salva.");
void Processo::connecting(){
     wifiManager.setAPCallback(configModeCallback);
     Serial.println("Abertura Portal"); //Abre o portal
     digitalWrite(26,HIGH); //Acende LED Vermelho
     digitalWrite(32,LOW);
     wifiManager.resetSettings();       //Apaga rede salva anteriormente
      if(!wifiManager.startConfigPortal("JJ Cientifica", "12345678") )
        { //Nome da Rede e Senha gerada pela ESP
        Serial.println("Falha ao conectar"); //Se caso não conectar na rede mostra mensagem de falha
        delay(2000);
        ESP.restart(); //Reinicia ESP após não conseguir conexão na rede
      else{       //Se caso conectar
        Serial.println("Conectado na Rede!!!");
        ESP.restart(); //Reinicia ESP após conseguir conexão na rede
   if(WiFi.status()== WL_CONNECTED){ //Se conectado na rede
      digitalWrite(32,HIGH); //Acende LED AZUL
   else{ //se não conectado na rede
      digitalWrite(32,LOW); //Apaga LED AZUL
      //Pisca LED Vermelho
      delay(500);
      digitalWrite(26,LOW);
      delay(500);
      wifiManager.autoConnect();//Função para se autoconectar na rede
  //callback para quando entra em modo de configuração AP
  //wifiManager.setAPCallback(0); //configModeCallback
  //callback para quando se conecta em uma rede, ou seja, quando passa a trabalhar em modo estação
  //wifiManager.setSaveConfigCallback(0);//saveConfigCallback
void Processo::run() {
bool flag_brx;
 String bufferBlynk;
 BLYNK_WRITE(V10)
     bufferBlynk = param.asString();
     flag_brx = true;
 BLYNK_READ(V0)
     Blynk.virtualWrite(V0, SensoresAtuadores[0].valorDeLeitura(COMPOSTO));
 BLYNK_READ(V1)
     Blynk.virtualWrite(V1, SensoresAtuadores[1].valorDeLeitura(COMPOSTO));
 BLYNK_READ(V2)
     Blynk.virtualWrite(V2, SensoresAtuadores[2].valorDeLeitura(COMPOSTO));
 BLYNK_READ(V3)
     Blynk.virtualWrite(V3, SensoresAtuadores[3].valorDeLeitura(COMPOSTO));
Processo &Processo = Processo.getInstance();
I was referring to post #22
The WifiManager I have installed does not contain the following method:
Can you give me a WifiManager that contains this method?
otherwise your code will be deleted.
I formatted the posted code. Is that what you’re talking about? Enclose in 3 quotation marks (```)?
They aren’t quotation marks, they are backticks.
The formatting is okay now.
Can you help me with this? Should I remove the library and install the blynk wifimananger library?
What exactly is it that you are trying to achieve, and why?
Your comment about…
makes no sense to me.
What I hope is to make a firmware that has the blynk token and that I can select the network and password if necessary. (no need to recompile the code again).
You’ll need to recompile the code if the token needs to be changed.
Why don’t you just use Blynk 2.0 WiFi provisioning?
The token will not be changed. What I want is to change the ssid and password at runtime. The code I posted does this, but it’s giving an error in the wifimanager library.
How do you know that?
It’s sometimes necessary to refresh the auth token in Blynk 0.1, and it may be necessary in Blynk 2.0 also.
It’s okay if I have to change the token. No problem, if you need I recompile. I have a machine that connects here at the company. When I bring it to the client I want to edit the network information without needing to recompile.
Which version of Blynk are you using, and what type of subscription plan do you have?
I’m using version 2.27.29.
I don’t have a monthly plan, I buy resources when I need them.
So you’re using Blynk 0.1, which will be retired in around 6 months time.
Using Blynk for commercial purposes is illegal without a subscription plan…
Commercial Use
Any of Blynk Products CAN NOT BE USED for any commercial purposes, including, but not limited to selling products and providing services which for any fare, fee, rate, charge or other consideration, or directly or indirectly in connection with any business, or other undertaking intended for profit or used for monetary gains or beneficial to a commercial entity.
The only legal way to use Blynk products and services for commercial purposes is to sign up for a paid licensing subscription plan listed here: https://blynk.io/plans
Who will buy the blynk is the customer who will buy the machine. I’m just going to market the hardware.
