I subscribed to the Kickstarter campaign. I bought 1 set for IOS
I haven’t started to “blynk” yet, as I’m still expecting my Ethernet shield, but I have a few questions:
I looks like there is no fee for using Blynk. If it’s the case, what have I bought on Kickstarter then ?
Can I “talk” to more than one Arduino, provided they each have their own Ethernet shield ?
Can I “talk” the the same Arduino, using either my Iphone or my Android tablet ? If so, how ?
I seriously think that you guys need to spend a bit of time, and create a decent user’s manual, that would answer all these questions. You have a promising product, but without proper documentation, you will only get a fraction of your potential clients !
I bought a DAEnetIP1 (www.denkovi.com) which is roughly doing (with a specific hardware) what yours is doing. It had the worst ever written user’s manual. It is now collecting dust. Needless to say, I did not recommend it to anyone !
Let’s make sure the same does not happen to Blynk !
You can start Blynking even without a shield. Some extra steps are needed to do so. @vshymanskyy can help you with that. Check the USB example in our library - it has all the instructions.
Yes, of course, just use the same Auth Token on every Arduino
yes, almost Just login with the same account. However in future it will work differently.
We were making Blynk so that no manuals are needed. Everything is pretty self-explanatory or is present in the examples. We plan to post video tutorials though.
Well I agree with Jasmin on the user manual part. For example, coding with Spark (well I mean Particle now) is great because the document is very precise and accurate, and with lots of example on each functions.
Yesterday I got blynk working, but I had to dig into the library .h to understand what is needed (no example provided for Particle core yet).
I am still a bit confused by what do you call a virtual pin for example. I couldn’t understand if the data is typed, I mean if I write a boolean or a long into a virtual pin, will it do the same?
So far the platform seems to be working, which is already a huge step specially considering that you delivered for Android and IOS and arduino/spark/orthers on the same day. That was ambitious!
Now I expect I will be able to build what I want quickly without reaching this forum too often for support.
