4 relays with 1 fan speed control by wi-fi, or manually with live feedback
Hello guys I am working on a project, which is 4 relays with 1 fan speed control(live feedback also)
i want to add one more condition in my project, related to fan speed control,
fisrt is one more button for fan on/off and one regulator switch for manually control of fan speed can someone help me,
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <RBDdimmer.h>
#define DEBUG_SW 0
#define S1 34
#define R1 18
#define S2 35
#define R2 19
#define S3 36
#define R3 21
#define S4 39
#define R4 22
#define outputPin  27  // PWM pin for dimmer
#define zerocross  25 // for boards with CHANGEBLE input pins
dimmerLamp dimmer(outputPin, zerocross); //initialase port for dimmer for ESP8266, ESP32, Arduino due boards
//#define LED1 26
//#define LED2 25
//#define LED3 27
//#define Buzzer 21
int MODE = 0;
int outVal = 0; // Intialisation value for dimmer
int dim_val; // dimmer value to dim the appliance
char ssid[] = "Yogendra";
char pass[] = "Jamsariya";
char auth[] = "";
int switch_ON_Flag1_previous_I = 0;
int switch_ON_Flag2_previous_I = 0;
int switch_ON_Flag3_previous_I = 0;
int switch_ON_Flag4_previous_I = 0;
BLYNK_WRITE(V0)  {  // Set to your virtual pin
  outVal = param.asInt(); // Get State of Virtual Button
  dim_val = map(outVal, 0, 1023, 0, 100); // mapped the value for dimmer
  dimmer.setPower(dim_val);               // Set dimmer power
  //Blynk.virtualWrite(V1, dim_val); //sending to Blynk
BLYNK_WRITE(V1)
  digitalWrite(R1, pinValue);
  // process received value
BLYNK_WRITE(V2)
  int pinValue = param.asInt(); // assigning incoming value from pin V2 to a variable
  digitalWrite(R2, pinValue);
BLYNK_WRITE(V3)
  int pinValue = param.asInt(); // assigning incoming value from pin V3 to a variable
  digitalWrite(R3, pinValue);
BLYNK_WRITE(V4)
  int pinValue = param.asInt(); // assigning incoming value from pin V4 to a variable
  digitalWrite(R4, pinValue);
void with_internet()
  if (digitalRead(S1) == LOW)
    if (switch_ON_Flag1_previous_I == 0 )
      digitalWrite(R1, LOW);
      if (DEBUG_SW) Serial.println("Relay1- ON");
      Blynk.virtualWrite(V1, 0);
      switch_ON_Flag1_previous_I = 1;
    if (DEBUG_SW) Serial.println("Switch1 -ON");
  if (digitalRead(S1) == HIGH )
    if (switch_ON_Flag1_previous_I == 1)
      digitalWrite(R1, HIGH);
      if (DEBUG_SW) Serial.println("Relay1 OFF");
      Blynk.virtualWrite(V1, 1);
    if (DEBUG_SW)Serial.println("Switch1 OFF");
  if (digitalRead(S2) == LOW)
    if (switch_ON_Flag2_previous_I == 0 )
      digitalWrite(R2, LOW);
      if (DEBUG_SW)  Serial.println("Relay2- ON");
      Blynk.virtualWrite(V2, 0);
      switch_ON_Flag2_previous_I = 1;
    if (DEBUG_SW) Serial.println("Switch2 -ON");
  if (digitalRead(S2) == HIGH )
    if (switch_ON_Flag2_previous_I == 1)
      digitalWrite(R2, HIGH);
      if (DEBUG_SW) Serial.println("Relay2 OFF");
      Blynk.virtualWrite(V2, 1);
    if (DEBUG_SW)Serial.println("Switch2 OFF");
    //delay(200);
  if (digitalRead(S3) == LOW)
    if (switch_ON_Flag3_previous_I == 0 )
      digitalWrite(R3, LOW);
      if (DEBUG_SW) Serial.println("Relay3- ON");
      Blynk.virtualWrite(V3, 0);
      switch_ON_Flag3_previous_I = 1;
    if (DEBUG_SW) Serial.println("Switch3 -ON");
  if (digitalRead(S3) == HIGH )
    if (switch_ON_Flag3_previous_I == 1)
      digitalWrite(R3, HIGH);
      if (DEBUG_SW) Serial.println("Relay3 OFF");
      Blynk.virtualWrite(V3, 1);
    if (DEBUG_SW)Serial.println("Switch3 OFF");
    //delay(200);
  if (digitalRead(S4) == LOW)
    if (switch_ON_Flag4_previous_I == 0 )
      digitalWrite(R4, LOW);
      if (DEBUG_SW) Serial.println("Relay4- ON");
      Blynk.virtualWrite(V4, 0);
      switch_ON_Flag4_previous_I = 1;
    if (DEBUG_SW) Serial.println("Switch4 -ON");
  if (digitalRead(S4) == HIGH )
    if (switch_ON_Flag4_previous_I == 1)
      digitalWrite(R4, HIGH);
      if (DEBUG_SW) Serial.println("Relay4 OFF");
      Blynk.virtualWrite(V4, 1);
    if (DEBUG_SW)Serial.println("Switch4 OFF");
    //delay(200);
void without_internet()
  digitalWrite(R1, digitalRead(S1));
  digitalWrite(R2, digitalRead(S2));
  digitalWrite(R3, digitalRead(S3));
  digitalWrite(R4, digitalRead(S4));
void checkBlynk() { // called every 3 seconds by SimpleTimer
  bool isconnected = Blynk.connected();
  if (isconnected == false) {
    MODE = 1;
   // digitalWrite(LED1, HIGH);
    //digitalWrite(LED2, LOW);
    //digitalWrite(LED3, LOW);
  if (isconnected == true) {
    MODE = 0;
    //digitalWrite(LED1, HIGH);
    //digitalWrite(LED2, HIGH);
    //digitalWrite(LED3, HIGH);
  if (DEBUG_SW) Serial.begin(9600);
  pinMode(S1, INPUT);
  pinMode(R1, OUTPUT);
  pinMode(S2, INPUT);
  pinMode(R2, OUTPUT);
  pinMode(S3, INPUT);
  pinMode(R3, OUTPUT);
  pinMode(S4, INPUT);
  pinMode(R4, OUTPUT);
  //pinMode(LED1, OUTPUT);
  //pinMode(LED2, OUTPUT);
  //pinMode(LED3, OUTPUT);
  //pinMode(Buzzer, OUTPUT);
  //delay(200);
  //delay(200);
  //delay(200);
  //igitalWrite(LED1, LOW);
  //delay(500);
  //delay(200);
  //delay(200);
  //delay(200);
  //digitalWrite(LED1, LOW);
  //pinMode(MODE, INPUT);
  WiFi.begin(ssid, pass);
  timer.setInterval(3000L, checkBlynk); // check if connected to Blynk server every 3 seconds
  Blynk.config(auth);//, ssid, pass);
  dimmer.begin(NORMAL_MODE, ON); //dimmer initialisation: name.begin(MODE, STATE)
  if (WiFi.status() != WL_CONNECTED)
    if (DEBUG_SW) Serial.println("Not Connected");
    if (DEBUG_SW) Serial.println(" Connected");
  if (MODE == 0)
    with_internet();
    without_internet();
Really?
Yet another fan control topic from you!
Anyone taking a little time to look through your previous topics on the forum will see that you’ve covered every conceivable question about controlling a fan with Blynk, Alexa, Google, IFTTT and physical buttons.
Each time the code is different and the requirements are different.
I for one am not going to get into discussion about yet another variation on this theme.
Hello sir, good to see you again ,
i just want to say one things , this is a project and i keep improve my project, that’s why, i ask question, and i thing nothing wrong about it,
i wish you will take part to improved my project , but no , thats fine
Anyone please
