whenever I try to upload the blynkblink code and i check the serial port it states [301] DHCP Failed!
I am running this on the regular blynk servers and dont have much of an idea on how to fix this. could anyone help.
Can you at least explain how your hardware is setup?
I’m using an arduino UNO with an ethernet shield. And a RGB led.
@possiblyanidiot I’m guessing you have entered incorrect details for the gateway etc in your sketch or you have faulty hardware. it is more likely to be the former.
Please provide your sketch and ensure it is formatted with the </> button.
Try connecting the ethernet shield from a switch (not directly from the router) . I heaved the same problem before with some kind of routers.
@Julian78 not sure if there is a restriction on what new Community members can do. So I have added your sketch below. I’ll take a look for any obvious problems.
Blynk lets you create beautiful drag-and-drop visual interfaces
for your projects in 5 minutes. And it works with almost every
hardware out there.
Docs, Tutorials, everything: http://www.blynk.cc
Github: http://github.com/blynkkk
Blynk Community: http://community.blynk.cc
Follow Us: http://www.facebook.com/blynkapp
http://twitter.com/blynk_app
You’ll need, in general:
- Blynk App (download from AppStore or Google Play)
- Arduino UNO or similar microcontroller board
- Decide how to connect Arduino to the Internet (USB, Ethernet,
Wi-Fi, etc.). Bluetooth is on the way.
example.
Let’s turn ON your LED with Blynk!
In this example we'll use Arduino UNO + Ethernet Shield
5 Steps guide:
(watch video tutorial here: )
1. Connect LED to Pin 9
( http://arduino.cc/en/uploads/Tutorial/simplefade_bb.png )
In the Blynk App:
2. Create New Project
3. Email yourself Auth Token. You can do it later at any time
4. Add a Button Widget. Select Pin D9 in Widget's Settings
5. Press Play icon. Enjoy Blynking!
#include <Ethernet.h>
#include <BlynkSimpleEthernet.h> // This part is for Ethernet stuff
char auth[] = "YourAuthToken"; // Put your Auth Token here. (see Step 3 above)
Blynk.begin(auth); // Here your Arduino connects to the Blynk Cloud.
// to avoid delay() function!
@possiblyanidiot which ethernet shield are you using?
Try the sketch below and ensure you enter your Blynk token and set the correct IP addresses. You need to install the extra Ethernet library as indicated (link provided in the sketch). Let us know if this works:
* ENC28J60BlynkTest.ino by Costas Arduino Ethernet
* This example shows how to use ENC28J60 (UIPEthernet library)
* to connect your project to Blynk.
* For this example you need UIPEthernet library:
* https://github.com/ntruchsess/arduino_uip
* Typical wiring would be:
* VCC -- 5V
* GND -- GND
* CS -- D10 D53 Mega
* SI -- D11 D51 Mega
* SCK -- D13 D52 Mega
* SO -- D12 D50 Mega
* INT -- D2
* Button in switch mode connected to D13 (on board LED), Green LED V3, Red LED V4
* Seconds of up time displayed on V0 and ON / OFF on V1
#include <UIPEthernet.h>
#include <BlynkSimpleUIPEthernet.h>
#include <SimpleTimer.h> // here is the SimpleTimer library
char auth[] = "token goes here"; // Mega Ethernet
byte arduino_mac[] = { 0xDE, 0xED, 0xBA, 0xFE, 0xFE, 0xED }; //DE:ED:BA:FE:FE:ED
IPAddress arduino_ip ( 192, 168, 10, 120);
IPAddress dns_ip ( 192, 168, 10, 90);
IPAddress gateway_ip ( 192, 168, 10, 90);
IPAddress subnet_mask(255, 255, 255, 0);
bool buttonstatus = true;
SimpleTimer timer; // Create a Timer object called "timer"!
Blynk.begin(auth, "blynk-cloud.com", 8442, arduino_ip, dns_ip, gateway_ip, subnet_mask, arduino_mac);
// check if connected here
int mytimeout = millis() / 1000;
bool didweconnect = true; // assume we connected ok
while (Blynk.connect(13333) == false) { // try for 40s to connect, standard is 10s with Blynk.connect()
// Wait until connected
if((millis() / 1000) >= mytimeout + 39){ // try for less than 39 seconds, then continue with sketch
didweconnect = false; // failed to connect
break;
if(didweconnect == false){
Serial.println("Failed to connect, check Ethernet connections.");
else{
Serial.println("Connected OK");
timer.setInterval(1000L, sendUptime); // send up time in seconds, update display widgets and LED's
digitalWrite(13, HIGH); // turn on onboard LED at start up
void sendUptime()
Blynk.virtualWrite(V0, millis() / 1000);
int ledstatus = digitalRead(13);
if(ledstatus == 1){
//Serial.println("Onboard LED is now ON ");
Blynk.virtualWrite(V1, "ON ");
Blynk.virtualWrite(V4, 0);
Blynk.virtualWrite(V3, 255);
else{
//Serial.println("Onboard LED is now OFF");
Blynk.virtualWrite(V1, " OFF");
Blynk.virtualWrite(V4, 255);
Blynk.virtualWrite(V3, 0);
if(Blynk.connected()){ // this ensures it doesn't just loop trying to reconnect
Do you have inserted an SD card? is your Ethernet shield working without Blynk at all?
What Ethernet shield are you using anyway? I use a loose ENC28J60 ethernet port and it works like a charm.
