Использую NodeMCU v3
Хочу подключить 2 датчика но не имею представления как это сделать со стороны кода
Start with this Sketch Builder example and get it working with one sensor:
This code creates a DHT object called dht
DHT dht(DHTPIN, DHTTYPE);
You could replace all lower case instances of dht
with dht1 then add additional lines to create a second DHT object called dht2
DHT dht1(DHT1PIN, DHT1TYPE);
DHT dht2(DHT2PIN, DHT2TYPE);
You can then read the two sensors separately:
float h1 = dht1.readHumidity();
float t1 = dht1.readTemperature();
float h2 = dht2.readHumidity();
float t2 = dht2.readTemperature();
Не работает
Мой код:
#include <DHT.h>
char auth[] = "BlynkToken";
char ssid[] = "SSID";
char pass[] = "Password";
#define DHT1PIN 2
#define DHT1TYPE DHT11
#define DHT2PIN 3
#define DHT2TYPE DHT11
//1 sensor
void sendSensor()
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V2, h);
Blynk.virtualWrite(V3, t);
//2 sensor
void sendSensor()
Serial.println("Failed to read from DHT2 sensor!");
return;
Blynk.virtualWrite(V3, h2);
Blynk.virtualWrite(V4, t2);
dht.begin();
Выдаёт такие ошибки:
C:\Users\im_os\Desktop\dht11_blynk_ino\dht11_blynk_ino.ino: In function 'void sendSensor()':
dht11_blynk_ino:24:13: error: 'h' was not declared in this scope
dht11_blynk_ino:24:25: error: 't' was not declared in this scope
dht11_blynk_ino:28:26: error: 'h' was not declared in this scope
dht11_blynk_ino:29:26: error: 't' was not declared in this scope
C:\Users\im_os\Desktop\dht11_blynk_ino\dht11_blynk_ino.ino: At global scope:
dht11_blynk_ino:34:12: error: redefinition of 'BlynkTimer timer'
dht11_blynk_ino:17:12: error: 'BlynkTimer timer' previously declared here
dht11_blynk_ino:35:6: error: redefinition of 'void sendSensor()'
void sendSensor()
dht11_blynk_ino:19:6: error: 'void sendSensor()' previously defined here
void sendSensor()
dht11_blynk_ino:39:13: error: 'h' was not declared in this scope
dht11_blynk_ino:39:25: error: 't' was not declared in this scope
C:\Users\im_os\Desktop\dht11_blynk_ino\dht11_blynk_ino.ino: In function 'void setup()':
dht11_blynk_ino:51:3: error: 'dht' was not declared in this scope
dht.begin();
exit status 1
#include <DHT.h>
#define DHT1PIN 2
#define DHT2PIN 3
//1 sensor
void sendSensor()
if (isnan(h1) || isnan(t1)) {
return;
Blynk.virtualWrite(V2, h1);
Blynk.virtualWrite(V3, t1);
//2 sensor
void sendSensor()
if (isnan(h2) || isnan(t2)) {
return;
dht.begin();
Поправил и всё-равно сыпет ошибками:
void sendSensor()
void sendSensor()
dht.begin();
exit status 1
I’d do it like this:
#include <DHT.h>
#define DHT1PIN 2
#define DHT2PIN 3
void sendSensor()
// Read sensor 1
Serial.println("Failed to read from DHT1 sensor!");
return;
// Read sensor 2
return;
dht1.begin();
dht2.begin();
timer.setInterval(5000L, sendSensor);
I’ve changed the timer to every 5 seconds because DHT11 sensors don’t like to be read too frequently.
Also, you are using virtual pin V3 for both t1 and h2
I’ve not changed this in my code, so you need to work-out which pins you want to use and make the changes
Спасибо <3
Работает)
