WS2812B 9rgb Bar back light using Adafruit feather Huzzah8266 over WIFI
I have managed to get the led’s to work using a Slider widget set to (V1).The code is listed below. New to programming but very interested in the process so I can move forward.Here is the list of problems I am having:
  1. The starting led is brighter, almost white, and does not show a change in color when using the slider widget, but the other 8 led’s work great.
  2. I do not understand what I need to do to set up a (V2) as a button in order to turn On/Off the board’s data pin(12).
  3. I would also like to create a slider to adjust brightness of the led string as well.
    Hoping for some help, but I understand there are much better projects than what I am asking for. Thank you!!
code
 * App project setup:
 *   Slider widget (0...500) on V1
#include <Adafruit_NeoPixel.h>
#define PIN 12
Adafruit_NeoPixel strip = Adafruit_NeoPixel(9, PIN, NEO_GRB + NEO_KHZ800);
char auth[] = "XXXXXXXXXXXXXXXXXXXXX";
char ssid[] = "XXXXXXXXX";
char pass[] = "xxxxxxxxx";
  strip.begin();
  strip.show();
BLYNK_WRITE(V2)
  int button =
BLYNK_WRITE(V1)
  int shift = param.asInt();
  for (int i = 0; i < strip.numPixels(); i++)
    strip.setPixelColor(i, Wheel(shift & 255));
    // OR: strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + shift) & 255));
  strip.show();
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  if (WheelPos < 85) {
    return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
  } else if (WheelPos < 170) {
    WheelPos -= 85;
    return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
    WheelPos -= 170;
    return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
Clone this project I created to control the WS2811/12/12b LED chips.
It has the control you’re looking for.
