Hello everyone ! someone can tell me why the board continues to disconnect? I think that the code is very basic … I don t understand what is incorrect …
Reading buttonState a thousand times a second will not help.
Go for a maximum of 2 lines of code in the loop and use SimpleTimer to call your functions. That is why SimpleTimer is one of the 4 libraries you must install to use Blynk.
The following compiles with CHANGE or RISING (normally RISING is better).
Commented out ESP8266 wifi(EspSerial) and placed #include <SimpleTimer.h> after #include <BlynkSimpleEsp8266.h>. Don’t think you need #include <SPI.h> either but I have left it in.
//#include <Ethernet.h>
//#include <BlynkSimpleEthernet.h>
char auth[] = "***************";
//ESP8266 wifi(EspSerial);
Blynk.begin(auth, "**********", "**********");
//Blynk.begin(auth);
// Wait until connected
// Notify immediately on startup
Blynk.notify("Device started");
// Setup a function to be called every minute
// timer.setInterval(60000L, notifyUptime);
// Setup notification button on pin 5
pinMode(5, INPUT_PULLUP);
// Attach pin 5 interrupt to our handler
attachInterrupt(digitalPinToInterrupt(5), notifyOnButtonPress, RISING);
void notifyUptime()
long uptime = millis() / 60000L;
// Actually send the message.
// Note:
// We allow 1 notification per minute for now.
Blynk.notify(String("Running for ") + uptime + " minutes.");
void notifyOnButtonPress()
// Invert state, since button is "Active LOW"
int isButtonPressed = !digitalRead(5);
if (isButtonPressed) {
Serial.println("Button is pressed.");
Blynk.notify("Yaaay... button is pressed!");
It’ll declare the function you made so the program knows it exists. Sometimes it’s needed (and truth be told, it’s nicer in terms of programming neat-ness : ) )
Yes there was a “feature” introduced around version 1.6.5 whereby the functions have to be in a specific order. They quickly realised this was a backward step and it was fixed in later versions.
It seems endless story …
I updated Java and now also Arduino IDE 1.6.9 …
They are not errors in the compilation … but when I press the button Wemos will disconnect …
My button is connected to GND and pin D4 (2 Arduino IDE)
I tried with two Wemos boards with the same result
char auth[] = "*************************";
//ESP8266 wifi(EspSerial); <-------- commented
Blynk.begin(auth, "TP-LINK", "*************");
// timer.setInterval(60000L, notifyUptime); <--------commented??
// Setup notification button on pin 2
pinMode(2, INPUT_PULLUP);
// Attach pin 2 interrupt to our handler
attachInterrupt(digitalPinToInterrupt(2), notifyOnButtonPress, RISING);
void notifyUptime()
int isButtonPressed = !digitalRead(2);
@n3v3r all the digital pins on the WeMos D1 and D1 Mini have full functionality (interrupt/pwm/I2C/one-wire support) with the exception of D0 (GPIO 16).
That said GPIO 0, 2, 16 (D3, D4 and D0) should only be used if you have no other pins available as it can mess up the flashing of your device (see below).
Are you using the D1 R2, Mini or the original D1?
Below is a “working” sketch running on my Mini with a button between ground and D4 (GPIO 2). You don’t need to do the digitalRead(2) because the attachInterrupt does this for you. Once you have it working you need to make the following changes:
Select another pin as GPIO2 will create problems for you.
Debounce the button.
Disable interrupt whilst you are running the notifyOnButtonPress() function and enable when it is finished. Failure to do this will certainly result in your device rebooting or worse, locking up.
Google has all the stuff you need.
// n3v3rButton.ino 24/8/16 Costas
char auth[] = "xxxxxxxxxx";
Blynk.begin(auth, "xxxx", "xxxxx");
void notifyUptime()
//int isButtonPressed = !digitalRead(2);
//if (isButtonPressed) {
Blynk.notify("Button is pressed!");
@Costas I tried to load the code that you suggested, trying to even change the pin from D4 to D1 to D5 etc. … if I open the Monitor Serial I see that the button is pressed, but at the same time Wemos D1 mini resets with this code :
[10014] Connected to WiFi
[10014] IP: 192.168.1.105
[10014] Blynk v0.3.8 on NodeMCU
[10014] Connecting to blynk-cloud.com:8442
[10205] Ready (Table: 1ms).
Button is pressed.
ets Jan 8 2013, rst causes: 4, boot mode: (1.7)
wdt reset
I do not think a debounce problem…
char auth[] = "*********************";
Blynk.begin(auth, "TP-LINK", "***********");
pinMode(14, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(14), notifyOnButtonPress, RISING);
void notifyUptime()
int isButtonPressed = !digitalRead(14);
delay (100);
It will reset because you haven’t disabled the interrupt whilst you do the processing. It is just to confirm that you can see the button is pressed.
If you comment out Blynk.notify(“Button is pressed!”) it should run for longer without crashing. Please confirm when you have tested this. It can handle a quick Serial.print but not a big long Blynk.notify process.
Ok now you understand that interrupts are very fussy. The procedure with interrupts is that when it is triggered is, disable the interrupt (to stop it triggering again), set a flag, enable the interrupt and a timer or loop() looks for the flag.
If you do it any other way your ESP will crash.
So add these global variables:
long prevZeroMillis = 0; // used to debounce button, set at 100 millis, 0.1s, debounce time
bool buttonChanged = false; // used to ensure button press is handled correctly
bool buttonStatus = false; // toggle on and off
Add a new function:
void BlynkButton(){ //lines below will crash the ESP in notifyOnButtonPress() function
if(buttonChanged){ // only do something if button state has changed
Change the notifyOnButtonPress function to:
void notifyOnButtonPress() // debounced, disabled interrupt and enabled interrupt
noInterrupts(); // disable interrupts
if(millis() - prevZeroMillis > 100) { // different buttons need different debounce period, test it
buttonStatus = !buttonStatus;
buttonChanged = true; // just set a flag for loop() or SimpleTimer to pick up
prevZeroMillis = millis();
interrupts(); // enable interrupts
In loop() add (can also be done with SimpleTimer):
if(buttonChanged){
BlynkButton();
Test it, confirm it works ok and then publish the code for others to use.
If we just gave you the full code at the start you wouldn’t learn anything.
in this case the board is disconnected after about 20 seconds …
char auth[] = "************";
Blynk.begin(auth, "TP-LINK", "********");
void notifyUptime()
timer.run ();
if(buttonChanged){
BlynkButton();
changing the time debounce … nothing changes
Now I do not see even the button state in the serial monitor
[6265] Connected to WiFi
[6265] IP: 192.168.10.248
[6265] Blynk v0.3.8 on Arduino
[6266] Connecting to blynk-cloud.com:8442
[6665] Ready (ping: 5ms).
Button is pressed.
Button is pressed.
Button is pressed.
Button is pressed.
Button is pressed.
Button is pressed.
Button is pressed.
Button is pressed.
Button is pressed.
Button is pressed.
Button is pressed.
Button is pressed.
Button is pressed.
Button is pressed.
Button is pressed.
Button is pressed.
Button is pressed.
Button is pressed.
Button is pressed.
Button is pressed.
Button is pressed.
Button is pressed.
Button is pressed.
Button is pressed.
Button is pressed.
Button is pressed.
Button is pressed.
Button is pressed.
Button is pressed.
Working fine here, you have bad wiring.
I am also getting the PUSH messages but remember it is a maximum of 1 per minute so don’t press the button too frequently.
