Voice control with Tasker,Autovoice , Blynk and Google Now.
First you have to download tasker and install tasker.To use tasker there are many tutorials on Youtube one can follow.
Download Autovoice and install it.Autovoice is a plugin that works with tasker.
Setting up is easy.Again youtube comes to hand with many tutorials.
Next is to download RESTask Api.
This procedure is from the Bylnk community.
Here is a tutorial on how to bind tasker and Blynk, via the restfull api blynkapi · Apiary
we will use a plugin called RESTask
we will fist cover how to write data :
- download the plugin https://play.google.com/store/apps/details?id=com.freehaha.restask&hl=en95
- open tasker, new task, click the “+”, plugin, then “RESTask”
- click the pen
- request type : PUT
- host : http://cloud.blynk.cc/your_token/pin/D1 (for real pin)
or http://cloud.blynk.cc/your_token/pin/V1 (for virtual pin) - enable “custom body”
- custom body : if you want to activated pin : [“1”]
if you want to deactivate pin: [“0”] - Go to “header tab”
- click “add more”
10 : name : Content-Type
value: application/json
you can check if your program work by clicking the play triangle, if it works, click the save icon and enjoy !
if you want to read data, you have to change:
step 4 : it will be “get” instead of “put”, and at
step 6: you have to uncheck the custom body
Your data will be stored in the tasker variable %rtres
ps : if you want to add more security between your phone and the server, check the discussion under this post
NB:5.should be (https://blynk-cloud.com/your_token/pin/D1 (for real pin) V1 (for virtual pin)
Blynk software
In my case i have use four virtual buttons to communicate with tasker/Restask.
// #define BLYNK_DEBUG
int state1;
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxx";
char ssid[] = "xxxxxxx";
char pass[] = "xxxxxx";
//WiFi.config(ip, gateway, subnet);
// Wait until connected
pinMode (2, OUTPUT); //relay pin
pinMode (12, OUTPUT); //relay pin
pinMode (13, OUTPUT); //relay pin
pinMode (14, OUTPUT); //relay pin
digitalWrite(12, LOW); //Turn off relay on GP12 on ESP 8266-12
digitalWrite(13, LOW); //Turn off relay on GP13 on ESP 8266-12
digitalWrite(2, LOW); //Turn off relay on GP02 on ESP 8266-1
digitalWrite(14, LOW); //Turn off relay on GP01 on ESP 8266-12
BLYNK_WRITE(V1) // turn light on - ESP 8266-12
int state1 = param.asInt();
if (state1) {
Serial.println("ON ");
Blynk.virtualWrite(V4, 255);// turn off led for light
Blynk.virtualWrite(V1, HIGH);//turn on V1 light
digitalWrite(12, HIGH); //Turn relay on pin GP12
Serial.println("OFF ");
Blynk.virtualWrite(V4, 0);// turn off led for light
Blynk.virtualWrite(V1, LOW);//turn off V1 light
digitalWrite(12, LOW); //Turn relay off pin GP12
BLYNK_WRITE(V2)// turn tv on - ESP8266-1 GPIO2
int state2 = param.asInt();
if (state2) {
Blynk.virtualWrite(V5, 255);// turn on led for TV
Blynk.virtualWrite(V2, HIGH);//turn on V2 for TV
digitalWrite(2, HIGH); //Turn relay on pin GPIO2
Blynk.virtualWrite(V5, 0);// turn off led for TV
Blynk.virtualWrite(V2, LOW);//turn off V2 for TV
digitalWrite(2, LOW); //Turn relay off pin GPIO2
BLYNK_WRITE(V3)// turn kitchen on - ESP8266-12
int state3 = param.asInt();
if (state3) {
Blynk.virtualWrite(V6, 255);// turn on led for kitchen light
Blynk.virtualWrite(V3, HIGH);//turn on V3 for kitchen
digitalWrite(13, HIGH); //Turn relay on pin GP13
Blynk.virtualWrite(V6, 0);// turn off led for kitche light
Blynk.virtualWrite(V3, LOW);//turn off V3 for kitchen
digitalWrite(13, LOW); //Turn relay off pin GP13
BLYNK_WRITE(V7)// turn conservatory on - ESP8266-12 GPI14
int state4 = param.asInt();
if (state4) {
Blynk.virtualWrite(V8, 255);// turn on led for conservatory
Blynk.virtualWrite(V7, HIGH);//turn on V7 for conservatory light
digitalWrite(14, HIGH); //Turn relay on pin GP014
Blynk.virtualWrite(V8, 0);// turn off led for conservatory
Blynk.virtualWrite(V7, LOW);//turn off V7 for conservatory light
digitalWrite(14, LOW); //Turn relay off pin GPo14
The hardware is home made.Using ESP8266-12 and ESP8266-01.It is best to use ESP8266-12
as it is more reliable and easy to wire.
I currently have 4 units built and will add some more as i require.
I hope you have as much fun trying this project as I have had buildig is.
