Virtual pins need a timer for Particle
Blynk works great to control pins and read pins using Particle Photon, but whenever I add a virtual pin it shows down to a crawl and goes on and off line a lot.
Reading the Blynk documents it says to add a timer like “SimpleTimer.h”, but this is an Arduino timer and I cannot load it into the Particle IDE. There is a timer from Spark called SparkIntervalTimer.h available, but I have been unable to implement it. (I don’t understand the example they give)
Does anyone have a easy way to add Virtual pins in Particle ? Or a simple example of a timer that works with Particle…
The code below reads the mills (uptime from Particle) and it works as a virtual pin, but it’s super slow and resets a lot.
thanks
Randy
```#include <blynk/blynk.h>
char auth[] = "771825b75e0c41778745953a*******";
#define PIN_UPTIME V5
  delay(5000);
  Blynk.begin(auth);
BLYNK_READ(PIN_UPTIME)
  // This command writes Arduino's uptime in seconds to Virtual Pin (5)
  Blynk.virtualWrite(PIN_UPTIME, millis() / 1000);
Try the threads that come up if you put SparkIntervalTimer in the search tool.
Thank you Costas that was just the extra push I needed. The trick is to not use the SparkIntervalTimer, but rather the SparkCorePolledTimer.h. which includes a simple example. I revised my code below and it works great.
#include "SparkCorePolledTimer/SparkCorePolledTimer.h"
SparkCorePolledTimer updateTimer(1000);
void OnTimer(void);
char auth[] = "771825b75e0c41778745953a581*****";
  updateTimer.SetCallback(OnTimer);
  delay(5000);
  Blynk.begin(auth);
  updateTimer.Update();
void OnTimer(void) {  //Handler for the timer, will be called automatically
