I had read something in this site about a video (or snapshot from ip-camera) widget.
Any status on this development?
From a security perspective this would be an outstanding addition.
Video confirmation that the garage door is open or closed or video monitoring after motion is detected are two of the more obvious applications.
An interesting option would be to integrate GoPro control and video streaming widgets. Many GoPro models are Wi-Fi enabled and can be interfaced with smartphones.
+1 for raspberry pi cam I would be so happy for some way to get a video feed onto blynk even if it’s just a window within the blynk app that could display a video feed from a separate server like IP address 192.168.0 xxxx:8001 then have say a blynk joystick or buttons to control pan & tilt ( I have all this working via my web api but to have it working in blynk would be perfect.)
From a bandwidth standpoint I feel like the ip address source would make the most sense (feeds/images don’t stream through Blynk servers). Maybe the programming could send ptz info, or what source displays under what circumstances (like different sources displayed when different motion sensors are tripped). But I’m definitely not well-versed on the video transport methods, codecs and protocols. They are quite varied!
Arduino basically gets everything through Blynk via C++. The RPi has the capability to do more things but just doesn’t speak the language that’s been heavily established over the years, which is what Blynk runs off of.
Just want to say that I was able successfully setup streaming server and pass stream from my pc to mobile device via external server. However in order to make public streaming server still a lot of work should be done.
I support this type of widget as well (also raised it months ago). For me, all I really need is an IP camera stream pull that I can embed in my Blynk app. Small window to show my security cam(s).
side stepping a bit, a web view widget with just a url setting and maybe a refresh interval could be used for streaming cams, would be extremely flexible, and could be used in an infinite number of ways…
a lot of cams have some form of embeddable web view, including most rpi webcam straming s/w (thinking on it, maybe it could have a filed to paste some html)
