You have had the wrong flash size since you started using the 12F. The IDE just gives you a default (which is not a 12F) and you need to make the selections for flash, baud etc etc.
Set it as 4M with 1M SPIFFS.
Compile at standard sketch (empty setup and empty loop) and let us now how that goes.
Sketch uses 221,999 bytes (21%) of program storage space. Maximum is 1,044,464 bytes.
Global variables use 31,564 bytes (38%) of dynamic memory, leaving 50,356 bytes for local variables. Maximum is 81,920 bytes.
Uploading 226144 bytes from C:\Users\Toshi2\AppData\Local\Temp\buildebf25e0338692218c57d14bc8d5b301d.tmp/sketch_aug15a.ino.bin to flash at 0x00000000
⌠[ 36% ]
⌠[ 72% ]
⌠[ 100% ]
@Dave1829 I guess it could be a router security issue.
I have uploaded your sketch and checked with Termite and all is fine here.
I know from your previous posts that you have port forwarding setup so you have been in to the router settings. I am not saying disable port forwarding but you might need to provide access to additional ports.
I also know you have â2 networksâ running i.e not all the network is on 192.168.1.x. I think you might have 192.168.10.x too but as the IP port is appearing in the IDE this might not be the issue.
